nogama3 0 Posted August 22, 2005 Report Share Posted August 22, 2005 guys, how do you remove the handles on the mk3? i undone the screw at the back but the handle deosn't budge, seems as if there's some hidden screws, any help appreciated. Link to post Share on other sites
Matt W 4 Posted August 22, 2005 Report Share Posted August 22, 2005 No hidden screws just the mechanism inside the door. You'll need to remove your door panel to see whats keeping it in place! Link to post Share on other sites
binliner 0 Posted August 22, 2005 Report Share Posted August 22, 2005 if you've undone the screw on the inside edge of the door you just need to slide the handle forward to unhook it and then pull it out back end first (by that I mean the end of the handle thats nearest to the back of the car) Link to post Share on other sites
nogama3 0 Posted August 22, 2005 Author Report Share Posted August 22, 2005 thanks guys. Link to post Share on other sites
robvr6 0 Posted August 23, 2005 Report Share Posted August 23, 2005 the fronts are a pain in the arse to get back in...be warned! Link to post Share on other sites
stockers 1 Posted August 24, 2005 Report Share Posted August 24, 2005 Posted: Tue Aug 23 2005, 11:50PMthe fronts are a pain in the arse to get back in...be warned!unless you are going for'de-locked' then you dont have worry sbout doing a quater turn in the lock to line up the barrel. Link to post Share on other sites
