funny noise when starting
please note i have new leads before suggesting new leads.
sounds like solenoid also running on 4 or 5 untill warm i thought these cars were reliable the 8v was more reliable vr6 for sale ive had enough of it already. overated piece of crap ~:(
its only started running like this the past 2 days
I've felt the same way about my engine on several occasions. An endless round of funny noises and leaks. Yet I did over 50,000 trouble-free miles in my last car (a 5-door Golf VR6) which had an identical engine, so I KNOW VR6s are reliable.
The problems with my engine all turned out to be minor, and I'm sure yours will too. If you've replaced the plugs & leads and one or more cylinders still isn't getting a spark, then it's probably your coil pack that needs replacing. Tthe part is readily available second-hand and easy to swap out.
