RIX 0 Posted April 25, 2006 Report Share Posted April 25, 2006 i bought a set off ebay de,they had only been used in the assembly plant(read 3km),only 260 euro´s plus shipping,he had some with zimmermann disc´s they where 295euro´s,these are complet set´s with caliper´s asswell. Link to post Share on other sites
Petesvw 0 Posted April 25, 2006 Report Share Posted April 25, 2006 Been tryin rich, can't find any! Obviously not looking hard enough.lolOne place had a waiting list for 'em! Link to post Share on other sites
VR6Rich 3 Posted April 26, 2006 Report Share Posted April 26, 2006 Try Dubshack on 02476 256387 Link to post Share on other sites
RIX 0 Posted April 26, 2006 Report Share Posted April 26, 2006 had a quick look could only find these,not the same iknow but very nice.http://cgi.ebay.de/Ate-High-Performance-Break-Kit-AUDI-S3-TT_W0QQitemZ7977697478QQcategoryZ57406QQrdZ1QQcmdZViewItem Link to post Share on other sites
Petesvw 0 Posted April 26, 2006 Report Share Posted April 26, 2006 Cheers rich, they sold there last set three days since : (Ta for the no: tho : ) Link to post Share on other sites
Petesvw 0 Posted May 10, 2006 Report Share Posted May 10, 2006 Cheers for the heads up on dubshack VR6rich (pint of voddy commin your way!)Nowt when i first rang, told me to ring back week after, as they were expecting another TT breaker in (wasn't gonna post that!)Hey presto, one week later, fully kitted ; ) Link to post Share on other sites
VR6Rich 3 Posted May 11, 2006 Report Share Posted May 11, 2006 Hmmmm pint of vodka....You got the brakes on then? How did you find the install? Did you use the TT calipers? Did you use goodridge hoses? Hows the braking now? As you can guess I still havnt put mine on! :-D Link to post Share on other sites
rohitanand 0 Posted May 11, 2006 Report Share Posted May 11, 2006 Guys - your advice would be really appreciatedHeres the scenario - I have a set of genuine TT Comps - No tyres yet and am thinking of doing the TT brake conversion and also lowering the car between 40-50mmWith the brakes altering the off set - will I get away with 215/40/17 tyres? or will I still have to buy a set of 205/40/17sPlease help im a little confused :^) Cheers guys Link to post Share on other sites
cadguy77 0 Posted May 11, 2006 Report Share Posted May 11, 2006 With the brakes altering the off set - will I get away with 215/40/17 tyres? or will I still have to buy a set of 205/40/17sIs offset altered? *-) Link to post Share on other sites
Seademon 0 Posted May 11, 2006 Report Share Posted May 11, 2006 This is the longest thread about TT brakes I've ever seen!UKMkIV forums recentley done a group buy for the whole kit for £250, not sure if someones already stated that but 11 pages about TT brakes is a bit much for me ha ha Link to post Share on other sites
VR6Rich 3 Posted May 11, 2006 Report Share Posted May 11, 2006 IIRC the offset of the hub is not altered, its just the position of the disk on the hub, hence needing spacers along with the caliper carriers to move the caliper to the 'right' position. Link to post Share on other sites
cadguy77 0 Posted May 11, 2006 Report Share Posted May 11, 2006 just what i thought Rich Link to post Share on other sites
Petesvw 0 Posted May 17, 2006 Report Share Posted May 17, 2006 Not quite on yet rich : (Just got some 16's on, so in a week or two when i get time mate : )Will keep you informed ; ) Link to post Share on other sites
Petesvw 0 Posted May 27, 2006 Report Share Posted May 27, 2006 Hmmmm pint of vodka....You got the brakes on then? How did you find the install? Did you use the TT calipers? Did you use goodridge hoses? Hows the braking now? As you can guess I still havnt put mine on! :-DFitted 'em today rich, absolute doddle.Yep, used the TT's.The braking is slightly better, not tons, but defo better!Just used the standard flexi as i was just testing the set up!Will fit stainless hoses and use dot 5 at a later stage! Link to post Share on other sites
FishWick 21 Posted June 3, 2006 Report Share Posted June 3, 2006 It's when you stomp on the pedal at 100+ that you notice the benefit of the 312s ;-) Link to post Share on other sites
RIX 0 Posted June 3, 2006 Report Share Posted June 3, 2006 yep had a quick blab from 200km/h and down(a little shake down test) they where still fine(i have ferrodo ds performance pads and std. disc.) Link to post Share on other sites
Chris1 0 Posted July 12, 2006 Report Share Posted July 12, 2006 hi not a fan of trawling through the 12 pages, don't have the time.just want to know if you please, will the 312mm TT225 calipers and discs fit straight on a 96 VR6 Highline? - if not what do i have to change thanks.hi by the way this is my first post. i'll post up some pics when the motors looking sweet(lower) Link to post Share on other sites
VR6Rich 3 Posted July 12, 2006 Report Share Posted July 12, 2006 You also need the carriers, 5mm longer caliper bolts and 5mm spacers. You dont need the calipers if you have 288mm brakes as they use the same calipers. Link to post Share on other sites
Chris1 0 Posted July 13, 2006 Report Share Posted July 13, 2006 ok, where will i get these bits from? cheers Link to post Share on other sites
VR6Rich 3 Posted July 13, 2006 Report Share Posted July 13, 2006 Read through the thread and find out! All details are within this thread, im not repeating everything! Link to post Share on other sites
VR6Fletch 0 Posted October 25, 2006 Report Share Posted October 25, 2006 Just completed this on my 1993 Mk3 which had shagged discs and pads anyway.Total kit list:Audi TT (225) calipers, carriers and discs (£100 from an off the bay deal)Goodridge stainless line kit - Stealth £85Disc regrind £30Pads £60Bolts (50mm hex head self colour) spring washers and stainless spacers £15Proper caliper paint - silver £18Fitting £115 dowm my local garage.Total cost: £405 which is quite a lot.Sold 280 calipers and carriers on the bay for £60 so final cost £365 which is less but a lot.With drilled discs behind my 17s though these would look the muts nuts. Still look pretty business like.Much better stoppers and still bedding them in. Instant improvement but not yet stomped on them as Kev suggest! I would recommend despite cost as I was never confident in the original VR brakes being used to high performance Honda brakes.My tips for this conversion are:1) If you replace the front hoses with stainless then you need to do all your lines as the remaining rubber ones will bulge and cause you a lot of probs.2) Shields are a pain and its taken a couple of gos to stop them from rubbing. I fitted cut back 280 shields.3) Initial bite and feel is not as good a "modern" braking systems. Kev helpfully explains that this is because you need the bigger master cylinder from a 4motion/TT to increase the overall braking pressure. This i a job for a pro.3) Bolts are a pain to source because of the uncommon pitch. I used a little company I found off the we in Lincolnshire. AP and others were no real help.Happy stopping. Link to post Share on other sites
Petesvw 0 Posted October 26, 2006 Report Share Posted October 26, 2006 Did you use 5:1? Link to post Share on other sites
VR6Fletch 0 Posted November 9, 2006 Report Share Posted November 9, 2006 No geezer I didn't - will it make a lot of difference? Link to post Share on other sites
stuey 0 Posted November 10, 2006 Report Share Posted November 10, 2006 After flicking through the golf+, i noticed that oem parts do a 315mm upgrade for mk4's. This consists of the discs, carriers and pagid fast road pads for £318. The carriers are Anniversary/TT225 in red, i guess these are ok?? If you have 288mm calipers you will need to add the 6mm spacers and longer bolts? How does this price compare to dealer? Link to post Share on other sites
craggsy 91 Posted November 10, 2006 Report Share Posted November 10, 2006 I priced carriers at Audi and they want around £100 a side just for carriers Link to post Share on other sites
