Justicevr6 0 Posted September 25, 2005 Report Share Posted September 25, 2005 Is it worth buying the harware for Vag Com, will it tell me things I would'nt be able to find out unless I had it and can I do things that I would not be able to do without it.CheersIan Link to post Share on other sites
dubloke 4 Posted September 25, 2005 Report Share Posted September 25, 2005 think you've answered your own question there ian, lol! def worth a buy i would say! Link to post Share on other sites
Nerih 0 Posted September 25, 2005 Report Share Posted September 25, 2005 yep lol.... Link to post Share on other sites
alanf 0 Posted September 25, 2005 Report Share Posted September 25, 2005 YEP go for it the sleepless night worrying about fault codes you pull up will be well worth it! !lol at time to much info is a bad thing! what things do you want to do with it? fit cruise control, change the clocks out for a set with the trip comp on them? shut down the ERG valve?.............. Link to post Share on other sites
Justicevr6 0 Posted September 25, 2005 Author Report Share Posted September 25, 2005 I just want to make sure everything is working as it should,as most know I have been going through the car full service ETC and when I boot it it soulds as if it is sucking too much air I also feel slight vibration through the gas peddle when booting it,It may just be me worrying to much but I want to get all I can out of the engine.http://en.openobd.org/locations.htm#vw_sharan_7m Link to post Share on other sites
