petervr6 0 Posted October 6, 2005 Report Share Posted October 6, 2005 hi agian another question after i have warmed the car up its a pig to start from hot. you have to turn the key for 5-10sec before it will start but only from hot. Link to post Share on other sites
mightyvr6 0 Posted October 6, 2005 Report Share Posted October 6, 2005 Sounds like the blue temp sensor needs replacing. It's located on the front of the thermostat housing. Link to post Share on other sites
petervr6 0 Posted October 7, 2005 Author Report Share Posted October 7, 2005 ok give that a try then hope it sorts it as its rather annoying. Link to post Share on other sites
petervr6 0 Posted October 17, 2005 Author Report Share Posted October 17, 2005 changed the blue sensor in the thermostat housing still a pig to start any thing else could cause this. Link to post Share on other sites
silverline 0 Posted October 17, 2005 Report Share Posted October 17, 2005 is there a valve that stops the fuel from draining back to the tank? if there is and its knackered then every time its started its having to pump fuel up to the engine rather than it already being in the system. Link to post Share on other sites
petervr6 0 Posted October 17, 2005 Author Report Share Posted October 17, 2005 hi im not sure what does it look like and were can i find it. Link to post Share on other sites
silverline 0 Posted October 17, 2005 Report Share Posted October 17, 2005 i aint that clever, i should think it would be a non-return valve some where in the fuel line. on/in the fuel distribution bar? i think the other guys would be of more help on that.have you checked for a fuel leak anywhere? fuel could be evaporating. seems like a fuel related problem to me. tried checking or replacing the fuel filter? Link to post Share on other sites
