That would be good, though the 'Click here to see list of new items' sort of does that. The only thing that annoys me with that is the limitation to only 50 posts.
On another forum I use, the similar function shows all threads since I last logged in, but in the same format as a usual forum index, so each thread only appears once, and you can tell which ones you have read by the colour of the title.
On another forum I use' date=' the similar function shows all threads since I last logged in, but in the same format as a usual forum index, so each thread only appears once, and you can tell which ones you have read by the colour of the title.
yep, that does seem a bit more user-friendly.
Not to play down the good work done in running this forum at all.
