petervr6 0 Posted October 13, 2005 Report Share Posted October 13, 2005 ok when i first turn my key i get this very loud grumbling/bubbling sound ive got somebody to turn the key and i had a listen it sounds like its coming from that big coil of wires sort of at the back on the right hand side the bunch that looks like you can twist the black bit and pull it apart should it make this sound that loud as it is kinda loud Link to post Share on other sites
VR6Pete 1,455 Posted October 13, 2005 Report Share Posted October 13, 2005 Sounds like AUX water pump to me... as i't's situated right behind what you are describing. it shouldnt be TOO loud though, but noticable if you have the bonnet up. Link to post Share on other sites
SankysVR6 1 Posted October 13, 2005 Report Share Posted October 13, 2005 Yes deffinatley sound like the aux water pump, might be on its way out. It should hum like a small electric motorEasy enough to change if it is Link to post Share on other sites
petervr6 0 Posted October 13, 2005 Author Report Share Posted October 13, 2005 ye i think you are both def right i can hear it in the car too with the bonnet shut if this is on its way out could this cause the prob i have with the wayer coming out that little over flow hole in the side of the expan tank. Link to post Share on other sites
