silverline 0 Posted October 25, 2005 Report Share Posted October 25, 2005 wasnt too sure where to post it but for those who are unsure of where the engine speed sensor is then i hope this helps: Link to post Share on other sites
uber-tub 0 Posted October 25, 2005 Report Share Posted October 25, 2005 That's a great help. I would never have found it... Link to post Share on other sites
jdhobbs90 0 Posted October 27, 2005 Report Share Posted October 27, 2005 Whats the easiest way to remove this sensor?? Link to post Share on other sites
richievr 1 Posted October 27, 2005 Report Share Posted October 27, 2005 it's only held in with a single bolt.. i think its a 5mm allen key . . .literally just undo then remove Link to post Share on other sites
silverline 0 Posted October 28, 2005 Author Report Share Posted October 28, 2005 yeah its about that. it can be a fiddle to get out specially with the engine in the car. mine was out and i had the gerbox off which made it easier.if yours is the original one then vw put the bolt in with locktite so they are proper tight but once you've cracked it off it should come out quite easily. Link to post Share on other sites
Devilfish 0 Posted October 28, 2005 Report Share Posted October 28, 2005 i have a fault with my speed sensor... what does it do???? and do ECP sell them ??? Link to post Share on other sites
silverline 0 Posted October 28, 2005 Author Report Share Posted October 28, 2005 i think the engine speed sensor and the camshaft sensor (or hall sensor) work together to measure engine speed and camshaft timing to ensure continuous smooth running. they are a bosch item so i think you can only get them from either vw or a bosch dealer. i know gsf dont do them. try ECP by all means.i know a good place that are bosch dealers who can get the engine speed sensor for Link to post Share on other sites
fritzenberg 3 Posted October 29, 2005 Report Share Posted October 29, 2005 it`ll work the rev counter too won`t it? Link to post Share on other sites
jdhobbs90 0 Posted October 29, 2005 Report Share Posted October 29, 2005 where is the 5mm bolt on the end or side of the sensor? cant seem to find it?? Link to post Share on other sites
silverline 0 Posted October 29, 2005 Author Report Share Posted October 29, 2005 the bolt is just to the right of the sensor as your looking at it.i thought the rev counter worked electronically off ignition timing? Link to post Share on other sites
