Devilfish 0 Posted November 4, 2005 Report Share Posted November 4, 2005 of my car is slowly falling apart.. !amazed radiator, abs sensors... !sad now i have what i think is a wheel bearing going on the passenger side and my CV joint drivers side is making a racket when turning. ~A few questions...I have a bearing kit from GSF is there a procedure online for replacing the bearing and is a press required for removal.The bearing i have looks like a normal, albeit large! ball race, i have only ever done the taper roller bearing type before. is it an easy job?also same question for replacing the front outside cv/uj is it an easy job?Many thanks in advance Devilfish. Link to post Share on other sites
Justicevr6 0 Posted November 4, 2005 Report Share Posted November 4, 2005 Very easy job to do,and as long as you are careful you do not need a press.knock the old bearing out and use it to hit the new bearing in,as happy Gilmore would say "tap it in just tap it in,tap tap tap" CV is a simple job as well. Link to post Share on other sites
Big P 1 Posted November 4, 2005 Report Share Posted November 4, 2005 Hi mate, i would suggest taking the gsf bearing back and getting a vag one, i used gsf bearings on the front of my old G60 and they needed replacing after a month cause they collapsed they were pressed in buy some one i trust and helped as well, in the end they paid for the proper ones.if it the front bearing i would recomend pressing them in, i did it second time myself, to get the old ones out i would press as well, a lot easier the smashing it out with a tube and having it only take one half out then have to bang the other side out as well, with a press you are more likely to get it in level as well, hope that helps Paul Link to post Share on other sites
DundeeDub 0 Posted November 4, 2005 Report Share Posted November 4, 2005 when i was doing mine i took the castings and the new bearings to a garage, 20 mins later and Link to post Share on other sites
