Dubsingh 0 Posted November 8, 2005 Report Share Posted November 8, 2005 hi allhave a dilema my 2.9 vr ODB1....The fan stopped workin...sorted that out not a problem i also wired an fan overide switch so that i could turn it on/off remotely....today the car temp was readin over 100 with the over ride on...oil temp nearly 127...wots gone wronh the fan is on but the air sucked away seems cold.....??????? thermostat????? where is it located???? how easy would it be to change...by the way the temp switch on the rad is also new replaced it today....i dnt wana blow the gasket (to exensive lol) i havent driven the car since this happed (once only) !dodge %-6 !dodge %-6 !dodge %-6 Link to post Share on other sites
Justicevr6 0 Posted November 8, 2005 Report Share Posted November 8, 2005 Doing a thermostat is quite a simple job to do albeit a bit fiddly, it is located under the coil pack,when you buy a thermostat make sure you get the housing rubber gassket as well as the thermostat one. Link to post Share on other sites
Dubsingh 0 Posted November 8, 2005 Author Report Share Posted November 8, 2005 i hear there are two water pumps on vr6 where are they l;ocated? pulley end and....? Link to post Share on other sites
NickRStorm 0 Posted November 9, 2005 Report Share Posted November 9, 2005 The electric one is mounted vertically on the back of the engine behind the coil pack Link to post Share on other sites
Dubsingh 0 Posted November 9, 2005 Author Report Share Posted November 9, 2005 cheers what are people views on removing the thermostat tottaly? i know the car will take longer to warm up but that shudnt be a problem.....i did it on my valver and it ran trouble free....i reckon this should aid running the car a bit cooler due to the supercgharger.... Link to post Share on other sites
silverline 0 Posted November 9, 2005 Report Share Posted November 9, 2005 the car may not reach its proper running temp with the thermostat removed poss causing the cold start injectors to continue running so your engine will run rich. Link to post Share on other sites
Dubsingh 0 Posted November 9, 2005 Author Report Share Posted November 9, 2005 hmmm this will only happen while the engine takes time to reach the temp required.... i am going to try and do something cleaver....will try and locate the thermostat in line so easier to change (summer/winter)....... ? the themostat seems to be at the end of the bottom hose not the top one as some threads seem to indicate.....has ne one got a picture of this are...mines ODB1 dizzy not coil..... Link to post Share on other sites
