mattverth 0 Posted November 9, 2005 Report Share Posted November 9, 2005 Hey guys,What really are the implications of tyres rubbing arches and liners?I imagine the answer is different if the tyre rubs more/less often, at what speed/whether it touches the metal arch lip of the plastic liner. I can definately see a feint line on the front tyres.Will it damage/bust the tyre/blowout/flip you over under extreme circumstances?And secondly, if I did roll the arches, it appears that the rears have a bigger lip than the front so the effect would be more noticeable (or not, if the tyre is only hitting the liners, then rolling would have no effect) and the fronts have a large rigid piece of plastic which forms the edge of the liner which looks like, due to its position, that rolling the tiny front metal lip wouldnt do much as the plastic would still be there. 17*7.5, et 35 about 40-50mm down on h & r coils.My first plan of attack is to go up 10mm as the front air dam plastic hits the deck on hard corners.Your thoughts? Link to post Share on other sites
binliner 0 Posted November 9, 2005 Report Share Posted November 9, 2005 if you have the front arches rolled you can either remove totally or chop back the plastic liner... with that drop and wheel size you shouldnt be getting too many problems... what size tyres? 205/40/17? Link to post Share on other sites
TVR6 0 Posted November 9, 2005 Report Share Posted November 9, 2005 If the arches rub on the tyres constantly they could begin to eat at the rubber which aint good :? Link to post Share on other sites
mattverth 0 Posted November 9, 2005 Author Report Share Posted November 9, 2005 They dont rub constantly, just occasional scuff when pressing on.Tyres are 205 40 17 Link to post Share on other sites
Pittuf 0 Posted November 9, 2005 Report Share Posted November 9, 2005 My rear tyres scrubbed to fcuk with the 8.5" wide wheels I have at the moment.....really cut hooge chunks out of the outer wall.I have now been running them for quite a while like this and was at first a little worried, but now I don't even think about it.....I'll post some pics tomorrow so you can see just how bad they were rubbing.Mine used to catch on the inner arches with my old wheels when hard cornering. It was rubbing on the inside of the wheel and you could see the marks on the inner arch when the wheel was removed.....I never worried about that at all as it wasn't very often.All the above is with a drop of about 60-65mmHope that helps mate. Link to post Share on other sites
mattverth 0 Posted November 10, 2005 Author Report Share Posted November 10, 2005 I just dont feel warm and fuzzy about losing rubber by rubbing - ooo errrr... but in all fairness, a blowout would be a pretty average experience.Having seen your photos pittuf, perhaps my drop is the same as /close to yours. There is no rubbing on the inside - I think - just the outside. Should have got 7" wide wheels! Link to post Share on other sites
aad 0 Posted November 10, 2005 Report Share Posted November 10, 2005 mines rubbing if on tight right and turns or full lock on passenger side front,back both rears pealing strands of tyreif it a bump on road. 7x15 wheels but was worse with oe highline rims my front passenger is the problem on arch lipshowing metal,paint as come off. would rolling them cure thistooo low.. Link to post Share on other sites
mattverth 0 Posted November 10, 2005 Author Report Share Posted November 10, 2005 I've actually seen a Commodore SS Ute over here with shizzle fo'sho bling razzle dazzle wheels with rubber bands for tyres - on bloody building site - which he had, as the chavs say, slammed, innit. The end result was a buckled front wing. Can you imagine? Link to post Share on other sites
aad 0 Posted November 10, 2005 Report Share Posted November 10, 2005 if i say reverse on to drive and turn a little the arch drops on to tyre the wing does do what u said trying to buccle wing...i love the o so shizzle me dizzle on me rizzle lmao...no i,ve got weitech suss on 75 mm drop ..cheers Link to post Share on other sites
binliner 0 Posted November 10, 2005 Report Share Posted November 10, 2005 Should have got 7" wide wheels!Just get the arches rolled and you'll be fine... I've got the same size wheels and tyres with quite a drop and get no rubbing at all Link to post Share on other sites
aad 0 Posted November 10, 2005 Report Share Posted November 10, 2005 thanks for the advise..nice pic,s.. Link to post Share on other sites
shinobi 0 Posted November 11, 2005 Report Share Posted November 11, 2005 i got 9's on the rear and have my arches rolled yet i still get rubbing when corner hard or fast over dips in roads.Need to get the arches flared me thinks Link to post Share on other sites
