fritzenberg 3 Posted November 13, 2005 Report Share Posted November 13, 2005 i recently had a bigger obd1 throttle body fitted,so doesthe standard ecu need reset? if so how do u do this?ta Link to post Share on other sites
VR6Rich 3 Posted November 13, 2005 Report Share Posted November 13, 2005 I think you only need to reset the ECU for the OBD2 throttle body as it is electronically controlled IIRC. Link to post Share on other sites
silverline 0 Posted November 13, 2005 Report Share Posted November 13, 2005 the obd1 throttle body needs resetting when the battery is disconnected. is that right? Link to post Share on other sites
jezmoz 0 Posted November 14, 2005 Report Share Posted November 14, 2005 the obd1 throttle body needs resetting when the battery is disconnected. is that right?is this right??? how do you do it??? Link to post Share on other sites
silverline 0 Posted November 14, 2005 Report Share Posted November 14, 2005 apparently it can only be done using VAG-COM but im not completly sure how right my statement is? Link to post Share on other sites
qgoose 0 Posted November 15, 2005 Report Share Posted November 15, 2005 In the camshaft sensor cleaning guide (top sticky in this forum group) it has some instructions that if you have to disconnect the battery for more than 15mins then you need to leave the key in the ignition turned to the on position (but not started) for about 20 minutes to reset something. Perhaps this is what you need to do?Hope this helpsSi (V)W Link to post Share on other sites
silverline 0 Posted November 15, 2005 Report Share Posted November 15, 2005 i was under the impression thats only for obd2 engine. but thats what i need some1 to confirm. Link to post Share on other sites
