B6MFD 0 Posted November 14, 2005 Report Share Posted November 14, 2005 no im not a druggy....loli was going to adjust my front coilovers yesterday but the front jacking pints are either nackered or really badly designed....i had to use the scissor jack as i cant fit my trolley under....there doesnt seem to be a ridge under there for the groove on the jack to fit on...so i slips off......has some fool nackered it or are they all like this? im buggered if i get a flat..... !dodge Link to post Share on other sites
SankysVR6 1 Posted November 14, 2005 Report Share Posted November 14, 2005 there should be a lip on the bottom of the sill. It might that some muppet mehcanic or owner could squashed the sill.If you look at the side of the car you should see to arrow heads pointing to the jacking points.as for the trolley jack, you need to make some wheel ramps out of wood and then drive on to the ramps and insert the jack Link to post Share on other sites
vr6highline28 0 Posted November 22, 2005 Report Share Posted November 22, 2005 sanky is that lip the piece of flat metal pointing towards the ground where the arrow is ? its just that i normally jack my car up using a support (part of the underbody) about 2 inches in from the sill - am i doing this wrong ? (ps need to know after knackering one of the solitudes !!!) - cheers - Adrian. Link to post Share on other sites
Nerih 0 Posted November 22, 2005 Report Share Posted November 22, 2005 yep, my car has that metal sill squashed flat, the rear one is okay though......ive had mine slip off the jack luckily, the damn thing fell sideways and it wasnt too high, so didnt get damaged.use a trolly jack under the cups near the jack points.. Link to post Share on other sites
six appeal 53 Posted November 22, 2005 Report Share Posted November 22, 2005 2 be honest mate, I'd be very careful using the VW scissor jack, only in a dire emergency (ie. flat tyre) I personally drive mine up onto a bit of wood and then this enables me to get the trolley jack onto the subframe of the car to get a good stable lift. Link to post Share on other sites
Pittuf 0 Posted November 22, 2005 Report Share Posted November 22, 2005 I've had my sills fixed recently....mine were all squashed like everyone elses it would seem.I have jacked up from the body work just further in from the sills....I found this broke the rubbery protective layer though....so decided against it.If you remove the splitter (if possible) from the front of the car you can jack it off a trolley jack at the front.And I think you can jack off the rear beam as well.....I'm not sure about that though. Link to post Share on other sites
gazchill 0 Posted October 11, 2006 Report Share Posted October 11, 2006 Hi,I know this is a little late given the discussion was a year ago but :-If there is only one jacking point on the car (If the scissors sill is knackered) how do i jack up and then support with stands. To do this you usually need two supports (One for the jack and one for the stands)I need to support the rear of the car, and from looking at the back I can't jack it up under the boot then put the supports by the wheels.Hope that made sense. Link to post Share on other sites
c4mbl 1 Posted October 11, 2006 Report Share Posted October 11, 2006 jack it up on the cross member, this will give you enough room to get the jack, and also the axle stand stand in, for support. Link to post Share on other sites
gazchill 0 Posted October 11, 2006 Report Share Posted October 11, 2006 ...mine has a rear anti roll bar under this. Any probs if i support the car on the roll bar? with a piece of wood between the bar and the stand OR would this damage the barThanks in advance. Link to post Share on other sites
c4mbl 1 Posted October 11, 2006 Report Share Posted October 11, 2006 As long as the whole weight aint on the anti roll bar then yeh thats fine, but dont support it using only the roll bar. Link to post Share on other sites
gazchill 0 Posted October 12, 2006 Report Share Posted October 12, 2006 OK - So does this mean I'm a bit scewed. I can trolly jack using the jacking point just behind the sill. But I can't support it because the rollbar is on.Everything I've read ses not to go under the car just with a jack.I'm wanting to do work on the brakes so I can't leave it on a ramp either. Link to post Share on other sites
