no im not a druggy....lol
i was going to adjust my front coilovers yesterday but the front jacking pints are either nackered or really badly designed....
i had to use the scissor jack as i cant fit my trolley under....
there doesnt seem to be a ridge under there for the groove on the jack to fit on...so i slips off......has some fool nackered it or are they all like this? im buggered if i get a flat..... !dodge
there should be a lip on the bottom of the sill. It might that some muppet mehcanic or owner could squashed the sill.
If you look at the side of the car you should see to arrow heads pointing to the jacking points.
as for the trolley jack, you need to make some wheel ramps out of wood and then drive on to the ramps and insert the jack
yep, my car has that metal sill squashed flat, the rear one is okay though......
ive had mine slip off the jack luckily, the damn thing fell sideways and it wasnt too high, so didnt get damaged.
use a trolly jack under the cups near the jack points..
I've had my sills fixed recently....mine were all squashed like everyone elses it would seem.
I have jacked up from the body work just further in from the sills....I found this broke the rubbery protective layer though....so decided against it.
If you remove the splitter (if possible) from the front of the car you can jack it off a trolley jack at the front.
And I think you can jack off the rear beam as well.....I'm not sure about that though.
  • 10 months later...
Hi,
I know this is a little late given the discussion was a year ago but :-
If there is only one jacking point on the car (If the scissors sill is knackered) how do i jack up and then support with stands. To do this you usually need two supports (One for the jack and one for the stands)
I need to support the rear of the car, and from looking at the back I can't jack it up under the boot then put the supports by the wheels.
Hope that made sense.
OK - So does this mean I'm a bit scewed. I can trolly jack using the jacking point just behind the sill. But I can't support it because the rollbar is on.
Everything I've read ses not to go under the car just with a jack.
I'm wanting to do work on the brakes so I can't leave it on a ramp either.
