head swap obd1-- obd2 ?
3 wire throttle plug is OBD1 mate. OBD2 throttle uses an oval multipin plug.
Heads are the same across all VRs, the only thing that differs is the chain gear. On late AAA engines the upper chain is simplex (single row) and early AAA and ABV use duplex upper chains, but just retain your existing cams etc and you'll be fine.
