Hoppa 0 Posted November 17, 2005 Report Share Posted November 17, 2005 After replacing my heater matrix on my ODB1 Vr, it was all running fine and then started overheating. Anyway managed to fix that at the weekend (think it was just an air lock). I'm now getting a horrible tapping sound as if there is no oil, and the oil light comes on when going round corners! Even though I have been topping up and there is plenty on dipstick....Is this sounding like a head gasket has gone? Any help will be appreciated. Link to post Share on other sites
Nerih 0 Posted November 17, 2005 Report Share Posted November 17, 2005 hmm, i would check the oil filler cap for milky residue, if there is, then you know the head is leaking, look out the back exhaust when its warm, if its steaming/white fumes, its gone.could be a seperate problem m8 ;(. but if its overheated, it might of knackered the headgasket, or the headgasket might of been leaking, hence the overheating lol .the oil light is to do with oil pressure, not oil level, so what that indicates, is that when you go round a corner, the oil presure drops, this is probably becuase the oil level is so low, that the oil moves to the side of the sump and you lose pressure. i would use your best judgement to 'guage' the accuracy of your dipstick, its simple tech, so it should give a decent measure of oil in your vehicle.the real question is, does your coolant expansion tank stink of fumes? is the water discoloured? are you losing coolant? Link to post Share on other sites
jon@vagworx 0 Posted November 17, 2005 Report Share Posted November 17, 2005 When you say 'it overheated' how hot did it actually get???If it went through the red, chances are it has either killed the head gasket or warped the head Link to post Share on other sites
stockers 1 Posted November 18, 2005 Report Share Posted November 18, 2005 if there is discolouration in the coolant reservoir it can just as easily be the oil cooler rather than the head, tapping and oil pressure does sound like Nerih said and that there isn't enough oil in Link to post Share on other sites
Hoppa 0 Posted November 18, 2005 Author Report Share Posted November 18, 2005 It got very hot, :@ , oil temp got to 120 Link to post Share on other sites
Nerih 0 Posted November 18, 2005 Report Share Posted November 18, 2005 120 degrees water and oil temperature, you've probably warped something inside m8, maybe your oil intake has fallen off and thats whats tapping!seriously, get it checked out asap, those are SERIOUSLY high temperatures....oil 120 i can understand, but water at 120 is very high... Link to post Share on other sites
Hoppa 0 Posted November 18, 2005 Author Report Share Posted November 18, 2005 Bo!!ox thats what i thought.....Glad i just spent loads of money sticking leather last month....not! wil let you know the outcome Link to post Share on other sites
Hoppa 0 Posted November 18, 2005 Author Report Share Posted November 18, 2005 Thinking about it...getting it skimmed, new gaskets and all the other probs its bound to have caused, would it be cheaper to get a new lump? Anyone know of any decent vw specialists in Kent who can fix this sort of thing? 8) Link to post Share on other sites
Nerih 0 Posted November 18, 2005 Report Share Posted November 18, 2005 when my gasket blew on my 4cylinder vw, it cost 400 to get it reskimmed and running like new, that included chemical bathing the head, of course a vr will cost a fair bit more, but i think you can get it done for 600, my garage here in london will do my head work and clutch for 800 which is very good, but then they've worked on our families car for yonks, i even met one of the mechanics at santapod when i was up there for the gti festival...find yourself a decent mechanic find out whats wrong, if anything, hell it could be something simple .if in doubt book it in at stealth, vince will let you watch, and you'll learn about your car at the same time, good prices excellent work. Link to post Share on other sites
silverline 0 Posted November 18, 2005 Report Share Posted November 18, 2005 i know of some where local to me who will skim a head for about Link to post Share on other sites
Hoppa 0 Posted November 18, 2005 Author Report Share Posted November 18, 2005 Your right. should get someone who knows what there on about to look at it....fingers crossed eh, thanks for your help lads Link to post Share on other sites
Nerih 0 Posted November 18, 2005 Report Share Posted November 18, 2005 yes, best of luck, hope it gets sorted properly and cheaply! Link to post Share on other sites
