jdhobbs90 0 Posted November 18, 2005 Report Share Posted November 18, 2005 Ive had my car in the garage for a week due to doing a few bits on it. I had it started a week ago due to getting a new battery, it started fine but then soon died without choking. I thought it was the low fuel level so i put some fuel in the car from a canister but now it only turns over but wont start. I have put in new spark plugs and distributor cap when it was first started. Please help, need to take it for an MOT tomorrow.! &| Link to post Share on other sites
Dubsingh 0 Posted November 18, 2005 Report Share Posted November 18, 2005 check your relays mine did the same and it turned out to be the ecu relay (could be fuel pump relay) do a fourm search for the number i think ECUI=109 hope this helps Link to post Share on other sites
jdhobbs90 0 Posted November 18, 2005 Author Report Share Posted November 18, 2005 Forgot to mention that i had already changed the fuel pump relay....is there anything else it may be?.....shot in the dark i know! Link to post Share on other sites
Dubsingh 0 Posted November 19, 2005 Report Share Posted November 19, 2005 hmmm so the car rototes when u turn the key...try fiddle with the fule pump relay....check for spar too....if no joy may have to vag com it Link to post Share on other sites
jdhobbs90 0 Posted November 19, 2005 Author Report Share Posted November 19, 2005 Are you supposed to get a buzzing noise from the fuel pump as it seems kind of quiet to me.......it def has fuel going to the fuel rail as i have checked the hose and it is coming through fine..messed about with the relay and still no joy.....anyone happen to be in the Wycombe area in Buckinghamshire with a vag cable??? !lol Link to post Share on other sites
jdhobbs90 0 Posted November 19, 2005 Author Report Share Posted November 19, 2005 I have also found there was a connector loose which is to the water pump i think? It is located on the right hand side of the engine as you look into the bay. The connector goes ito the top and when i connect it is is making a whirring/buzzing noise......could that cause the problem and is it normal to make that noise? Link to post Share on other sites
28v6r 0 Posted November 19, 2005 Report Share Posted November 19, 2005 Change the relay back for the old one first it may be that the relay was insecure in its holding... then check for the fuel pump priming as you turn on the ignition, yes, as you are about to start the car you should hear the pump buzz/hiss very quietly if its loud then the pump maybe on its way out. I suggest going back to the old realy only because in your previous postings you mention that It starts...seems a logical place to start... Link to post Share on other sites
jdhobbs90 0 Posted November 19, 2005 Author Report Share Posted November 19, 2005 Cn someone confirm exactly which relay is the fuel pump..? Has anyone a diagram of the fuse box? changed back to old one but want to be sure its the right one first.... Link to post Share on other sites
jdhobbs90 0 Posted November 19, 2005 Author Report Share Posted November 19, 2005 Also noticed the lighs dip a lot when turning the ignition, but its a new battery... started first time when i brought a new battery last week? do you think it needs a charge again after turning it over so much? I just want my car back!!! ~ Link to post Share on other sites
silverline 0 Posted November 19, 2005 Report Share Posted November 19, 2005 the lights will dip because the starter is drawing so much current from the battery. dont turn it over with the lights on as that will drain the battery unnecessary amounts.the fact that there is fuel at the engine makes me doubt that the pump is not working, you should hear the pump buzzing when the engine turns over.you need to check that there is actually a spark, if it isnt even trying to fire then its likely there is no spark. Link to post Share on other sites
apd 0 Posted November 20, 2005 Report Share Posted November 20, 2005 167 is fuel pump relay.109 voltage stabiliser relay. Link to post Share on other sites
jdhobbs90 0 Posted November 20, 2005 Author Report Share Posted November 20, 2005 Thanks....i'll check for a spark and to see if the rotor arm is turning. Link to post Share on other sites
jdhobbs90 0 Posted November 20, 2005 Author Report Share Posted November 20, 2005 ok, rotor arm is turning but dont seem to be getting a spark from the leads? could this mean i need new leads? i have also recently changed the distributor cap. Link to post Share on other sites
jdhobbs90 0 Posted November 20, 2005 Author Report Share Posted November 20, 2005 is there a way to test to see if im getting anything from th starter motor? Link to post Share on other sites
28v6r 0 Posted November 20, 2005 Report Share Posted November 20, 2005 Errr...But Why? The starter turns the block over, therefore if as you say the engine turns over then the starter is working... regards the lack of spark, are you sure you reconnected everything, i.e there is an earth wire that should bolt onto the Dizzy, probably on one of the screws that hold the cap on, if this is missing then "No sparky". Take the plug leads off individually and put an old plug in and see if theres a spark by earthing it to the block, i.e touch the block using insulated pliers otherwise you'll get a mighty kick out of it.... !dodge :@ Check the Cap to see that the centre Carbon electrode is still in place, if not then "No Sparky"... &| Failing this then look for a hall sender , an amplifier that enhances the spark, it maybe faulty, if so then again "No Sparky"...Try that and see how you get on.... Link to post Share on other sites
jdhobbs90 0 Posted November 20, 2005 Author Report Share Posted November 20, 2005 Looks like no spark at all, may be the ignition lead from the starter? Where is the hall sender located?mechanics course for me i reckon!! Link to post Share on other sites
Dubsingh 0 Posted November 20, 2005 Report Share Posted November 20, 2005 hall sender is below the dizzy i think not sure new to the VR game how did you check for the spark on the leads??? Link to post Share on other sites
jdhobbs90 0 Posted November 20, 2005 Author Report Share Posted November 20, 2005 checked for a spark by putting the lead against the body/block as 28v6r states above....how easy is it to get to the hall sender on an OBD1? Link to post Share on other sites
Dubsingh 0 Posted November 21, 2005 Report Share Posted November 21, 2005 not sure will check and find out for you mines OBD1 too Link to post Share on other sites
jdhobbs90 0 Posted November 21, 2005 Author Report Share Posted November 21, 2005 After all this stress, looks like i have a faulty coil! Cheers for all the help guys!! Anyone know where i can get a decent priced one? Link to post Share on other sites
Dubsingh 0 Posted November 22, 2005 Report Share Posted November 22, 2005 sandburns...on 02476 663 7376 speak to chris...tell him G gave you the number Link to post Share on other sites
silverline 0 Posted November 22, 2005 Report Share Posted November 22, 2005 is it a beru one? Link to post Share on other sites
Dubsingh 0 Posted November 22, 2005 Report Share Posted November 22, 2005 beru?? Link to post Share on other sites
jdhobbs90 0 Posted November 22, 2005 Author Report Share Posted November 22, 2005 Ok, got one for Link to post Share on other sites
28v6r 0 Posted November 26, 2005 Report Share Posted November 26, 2005 Can you be a bit more specific John, i.e can you display a photo.. just to see if we can help... Link to post Share on other sites
