Can anyone tell me where abouts the outside air temp sensor is? Are these known for packing up at all? Mines worked twice in the year that I've had the car so Im hoping its just a bad connecttion etc
If I need a new one how much are they roughly?
Cheers!
Dunno if its the same on my Passat.. however the sender is in the grill along side the Fog lamp. You can get at it from both the outside by removing all the vents/grills or alternatively from down the driverside wing beside the headlights and may require the headlight/radiator removal to get at it... all depends how easy you want to make it... ;):P
