bonnet not opening same time as battery terminal coming loose
Yesterday was probably one of the worst days i've had with the car. The curse of the vr strook big time. I left work and thought i'll pop into barryfords to get some demisting stuff (rain x). Came out of halfords and went to start the car, no dice. I knew that one of the battery terminals keeps coming loose ( i don't know why? it's tightened, it just doesn't grip). So i went to pop the bonnet, no response (it wouldn't open!!!!) So I took the grill off, breaking the top clips :(, thinking i'd be able to tug at the wire and open the bonnet, nope wont budge!! So i had a look and i could see the battery terminal, it was just slightly off (but wasn't the usual neagtive, it was the +), so i took a windscreen wiper off the car, not the blade the metal bit and poked around under tiny gap in the bonnet (the man in halfords leant me a torch, pliers and socket set (it was dark). After two hours in halford car park looking like a complete tosser i finally managed to poke the terminal on, went to start the car and BINGO, it started 8) . Drove home and realised that this would probably happen again and i needed to get the bonnet working. After reading on here a thread about the same thing i phoned pete8tch realising he'd had the same problem. The realisation that I would have to ruin the car came to light and I began sawing at the fibre glass (to the annoyance of the neighbours) to reveal the nuts that hold the bonnet lock, this was simple enough, but once i could actually see the nuts they were in an awkward postition, not quite enough room for a socket or spanner, I spent a good hour getting these nuts off, tiny bit of movement every turn, absolutely no leaverage. Finally got the bonnet open, the cable was still attached!!! I think the cable may be stretched because the catch seems to work fine when i manually move it!
Q 1. How can i stop the terminals from coming off (they are tight) but still come off by hand easily!
2. Should i replace both the bonnet cable and catch or just the cable?
3. Should i replace the fibre glass i've damaged, it holds the chassis number plate on it!
4. Why did i buy an old car??
Moral of the story, replace your bonnet cable while you can ;)
The bonnet cable is a 2 piece item, think you'll find the connector (about half way up the drivers side inner wing) has snapped, as this is what happened to mine.
No need to bust the fibreglass to undo the bonnet, remove the grille and then just pop the lever to open the catch.
To stop the terminals comming loose, first replace the nut/bolts on the terminals as these often loose there thread easily and so will not tighten up enough, and rough up the poles of the batteries themselves to stop the connectors slipping off.
Hope this helps,
Simon.
The bonnet cable is a 2 piece item' date=' think you'll find the connector (about half way up the drivers side inner wing) has snapped, as this is what happened to mine.
Hope this helps,
Simon.
The mid section clip was fine, i tried everything to 'pop the lever', it wouldn't budge, so had no choice but to butcher. The cable must be stretched???
the thread on the nuts on the terminals are fine, but i will try roughing the poles , cheers
Sorry to hear of your troubles. :(
Have you got the correct battery fitted?
If your battery has tapered terminals and the clamps are straight cut, they'll always slip off. Had this on another car before, changing the battery to one with straight sided terminals cured it.
I tried just cutting a section out but couldn't get tio the nuts so i cut all round it about the size of a letterbox (basically all round the lock area to give me room to get a spanner in, because i couldn't get to the nuts with any of the tools i had. You can't see it with the grill on.
the terminals are round as are the battery poles ' date=' the terminals wont seem to tighten to it, they were fine when i first had it fitted
If they fit together flushly then it can only be the bolts/nuts stopping you getting enough clamping pressure.
It is shrouded' date=' but you can get around it with a lever as I did ;o)
Simon.
sorry but i can't see how you did this, unless you have minature hands and a tool that can do an 's' bend ! :|
Only explanation I can think of is the front panels being different then mate, as I had my cable snap on me ages ago and managed to get the grille off and unhook the bonnet with out damaging anything besides a small nick in the grille.
I did a post on it on here at the time, as I was as P*ss*d off as you were at the time :o(
Simon.
