stockers 1 Posted November 28, 2005 Report Share Posted November 28, 2005 hi all, my idle is a bit high i think, idle at 900-950 rpm it starts at 1100 then drops to 900-950. also it will drive itself, in second gear if i take my foot off the accelerator peddle the car will continue to drive at the same speed!is it just cos the weather is cold at the moment?? :| Link to post Share on other sites
Eat this 2 Posted November 28, 2005 Report Share Posted November 28, 2005 mine idles at 1k ish on choke Link to post Share on other sites
Petesvw 0 Posted November 28, 2005 Report Share Posted November 28, 2005 Mines 1k on auto choke also. 8-9 when its off. Link to post Share on other sites
Dubsingh 0 Posted November 28, 2005 Report Share Posted November 28, 2005 shit mine idela at arond 500 600 but its a bit rough intermintently Link to post Share on other sites
stockers 1 Posted November 28, 2005 Author Report Share Posted November 28, 2005 cheers guys, put my over worrying mind at rest! Link to post Share on other sites
Eat this 2 Posted November 28, 2005 Report Share Posted November 28, 2005 mine sits at 600 rpm normally but its intermittently hunting atm Link to post Share on other sites
silverline 0 Posted November 28, 2005 Report Share Posted November 28, 2005 mine sits at 600 rpm normally but its intermittently hunting atmlike wise. been told its a dirty throttle body and isv. got to take it off clean it up then get the throttle reset. Link to post Share on other sites
Eat this 2 Posted November 28, 2005 Report Share Posted November 28, 2005 i dont have an isv mines obd2 it could be cam sender (behind coilpack) Link to post Share on other sites
silverline 0 Posted November 28, 2005 Report Share Posted November 28, 2005 point. i ve changed hall sensor and engine speed sensor and its no better. it had better be the isv?! (mines obd1) Link to post Share on other sites
Eat this 2 Posted November 28, 2005 Report Share Posted November 28, 2005 isv is 1st thing id do on obd1 Link to post Share on other sites
Nerih 0 Posted November 29, 2005 Report Share Posted November 29, 2005 720RPM on mine, if its obd1 do the ISV...tbh easiest thing to be do is to stick it on vagcom, if the tbody's dirty it'll have high adaptation values...also it could identify other issues.also items like the aircon, headlights, rear windscreen demister all use up power and increase revs. Link to post Share on other sites
silverline 0 Posted November 29, 2005 Report Share Posted November 29, 2005 its been on VAG COM and came out with nothing apart from the buterfly in the throttle body is 10 degrees too far open and they say its because of carbon build up so i will take it off and clean it all up and see what happens. Link to post Share on other sites
binliner 0 Posted December 1, 2005 Report Share Posted December 1, 2005 mine has started to intermittently idle at 2000rpm. it does it when Im driving and dip the clutch to change gear... it goes to 2krpm and stays there! what the hell is that all about? Link to post Share on other sites
stockers 1 Posted December 1, 2005 Author Report Share Posted December 1, 2005 i've put it down to s*** awful weather lol Link to post Share on other sites
binliner 0 Posted December 1, 2005 Report Share Posted December 1, 2005 I think its a tb problem but Im going to get it on vag com Link to post Share on other sites
stockers 1 Posted December 1, 2005 Author Report Share Posted December 1, 2005 i had mine vag com'ed at stealth when it went into have the coilies done and it came back clear, someone suggested on e38 cleaning the breather pipe? Link to post Share on other sites
binliner 0 Posted December 1, 2005 Report Share Posted December 1, 2005 what breather pipe... dont think I have one anymore Link to post Share on other sites
stockers 1 Posted December 1, 2005 Author Report Share Posted December 1, 2005 ah... that could be a problem then, i was hoping the ecu could be tweeked to adjust the idle? Link to post Share on other sites
