Hoppa 0 Posted November 30, 2005 Report Share Posted November 30, 2005 Anyone know if the above is likely to be a big problem to do? or anything to look out for?Cheers Link to post Share on other sites
jezmoz 0 Posted November 30, 2005 Report Share Posted November 30, 2005 you don't mess about do you , first the interior now the engine good luck matey Link to post Share on other sites
FishWick 21 Posted December 1, 2005 Report Share Posted December 1, 2005 Depends how old the current 2.8 VR6 is because if it's a dizzy one, you'll need the looms etc off the 2.9 car (corrado I assume?) for the coilpack and cam sensor etc. You'll also need the 2.9 ECU (AG) if that's the case. Link to post Share on other sites
Hoppa 0 Posted December 2, 2005 Author Report Share Posted December 2, 2005 you don't mess about do you ' date=' first the interior now the engine good luck matey[/quote']I know....should of just bought another one! lol Link to post Share on other sites
uber-tub 0 Posted December 4, 2005 Report Share Posted December 4, 2005 are all corrados on coilpacks? Link to post Share on other sites
Nerih 0 Posted December 5, 2005 Report Share Posted December 5, 2005 ive been told all corrado's are odb1 .... Link to post Share on other sites
antera309 3 Posted December 5, 2005 Report Share Posted December 5, 2005 Yes, all Corrados are OBD1. Early ones (pre-1993 I think) have a distributor, later ones have a coilpack, same as the OBD1 Golf VR6.If your current 2.8 engine and the 2.9 you're putting in are both OBD1 coilpack type, all you need to swap is the ECU and the engine itself. You can use your existing wiring loom.If going from a 2.8 coilpack to 2.9 distributor, you need to swap in the the engine wiring loom from the donor car. Link to post Share on other sites
