Justicevr6 0 Posted December 15, 2005 Author Report Share Posted December 15, 2005 I put Link to post Share on other sites
moleman 0 Posted December 18, 2005 Report Share Posted December 18, 2005 i've got a gas convertion on my other car (that i've just writen off) and its awesome, 40p a litre, and they do all different size tanks that pretty much fit anywhere on a vehicle, mainly underneath, the bloke who did my convertion works from home so he's a lot cheaper, his e-mails burngas@hotmail.com if you fancy asking the question, Link to post Share on other sites
Eat this 2 Posted December 18, 2005 Report Share Posted December 18, 2005 I put Link to post Share on other sites
Justicevr6 0 Posted December 18, 2005 Author Report Share Posted December 18, 2005 Can't find the site or person I got the information from but it is true, if you open the drivers door and put the key in the ignition and turn it on but don't start it and leave for 25/30 seconds it will reset and calibrate the throttle body,I don't know about OB1 but it works on my OB2. Link to post Share on other sites
Eat this 2 Posted December 18, 2005 Report Share Posted December 18, 2005 Can't find the site or person I got the information from but it is true' date=' if you open the drivers door and put the key in the ignition and turn it on but don't start it and leave for 25/30 seconds it will reset and calibrate the throttle body,I don't know about OB1 but it works on my OB2.[/quote']i know im well aqainted with this procedure recently lol Link to post Share on other sites
Justicevr6 0 Posted December 18, 2005 Author Report Share Posted December 18, 2005 Link to post Share on other sites
jcorallo 0 Posted January 5, 2006 Report Share Posted January 5, 2006 if you have any leaks in the exhaust BETWEEN the ENGINE and CAT - this will most certainly affect running.The reason is that, believe it or not, the leak will actually be letting air INTO the pipe which messes up the LAMBDA readings being sent to the ECU. If the ECU thinks it sees too much OXYGEN - it will ADD fuel.Get your exhaust sealed peoperly and try again.Jules Link to post Share on other sites
vr6turbo 27 Posted January 6, 2006 Report Share Posted January 6, 2006 check the lamba (o2 sensor) when these go down you mpg goes down :! had this happen to me and my mpg went down to about 15mpg Link to post Share on other sites
