flexin 0 Posted December 9, 2005 Report Share Posted December 9, 2005 i have a golf vr6 and have noticed that a small pipe has broken it is located on the left had side of the engine between the blosk and the inducion pipe and has a small round block in the middle of it i was wondering if anyone knows what it is, what it does and if it is important?thanks Link to post Share on other sites
the matrix 0 Posted December 12, 2005 Report Share Posted December 12, 2005 Flexin,Sounds like its your oil breather pipe. Mine went on mine last year when i was replacing the air filter with my induction kit. Common problem apparently, its a weak area and perishes easily. Not cheap to replace either! Link to post Share on other sites
Eat this 2 Posted December 12, 2005 Report Share Posted December 12, 2005 iv fixed mine with a frostys box worked perfectly lol Link to post Share on other sites
mightyvr6 0 Posted December 12, 2005 Report Share Posted December 12, 2005 I'd just replace it with a rubber hose. Second option is to get the part from Ford where I believe it's cheaper. Link to post Share on other sites
Eat this 2 Posted December 12, 2005 Report Share Posted December 12, 2005 yeah the galaxy is a sharan which has a vr6 Link to post Share on other sites
antera309 3 Posted December 12, 2005 Report Share Posted December 12, 2005 Yes, it's a very common problem. Do a search for "Crankase Breather" on this forum and you'll see various solutions.Getting the complete breather pipe from Ford (for a Galaxy VR6 up to 1998) seems to be the preferred option. Link to post Share on other sites
flexin 0 Posted December 13, 2005 Author Report Share Posted December 13, 2005 hey guys thanks for the advice i've decided to go for a oil breather filter.do these make any diffrance to performance or are they just for show?thanks Link to post Share on other sites
Big P 1 Posted December 13, 2005 Report Share Posted December 13, 2005 Has anyone got the part numbers from ford? i need to replace mine as well and about fell over when the guy told me how much it was from the stealersCheers paul Link to post Share on other sites
richievr 1 Posted December 13, 2005 Report Share Posted December 13, 2005 or you should be able to get 7M0 128 101 from vw - it's that part for a 97 sharan ....ought to do the trick... Link to post Share on other sites
Big P 1 Posted December 13, 2005 Report Share Posted December 13, 2005 or you should be able to get 7M0 128 101 from vw - it's that part for a 97 sharan ....ought to do the trick...Lovely thanks buddy, will give that i try 8) Link to post Share on other sites
vr6 g3 0 Posted December 13, 2005 Report Share Posted December 13, 2005 Does this part number defintly fit the golf ???Thanks Link to post Share on other sites
Nerih 0 Posted December 13, 2005 Report Share Posted December 13, 2005 oil breather filter will do nothing for performance, it's just to make sure you dont get a pressurized crank case, usually at high rpms the oil vapour will come out and be fed back into the inlet pipe work, which means ur getting oily air in ur engine, a breather is a good idea actualy, on the rollers a bit of oil smoke comes out of the breather, vince at stealth told me this is normal. Link to post Share on other sites
