stuey 0 Posted December 10, 2005 Report Share Posted December 10, 2005 Hi , i was thinking of getting a K&N panel filter for the original airbox, and have seen that the cone/trumpet inside can be removed for a bit more induction noise, but can it be replaced if need be? I don't want to pull it out and then find it can't go back if i want to replace it. Cheers !lol Link to post Share on other sites
fritzenberg 3 Posted December 10, 2005 Report Share Posted December 10, 2005 i tried to remove mine but it wouldn`t budge so i just left it in.got a feelin that u may need to break something to get it out. Link to post Share on other sites
ingham 5 Posted December 10, 2005 Report Share Posted December 10, 2005 they are just very tight Link to post Share on other sites
fritzenberg 3 Posted December 10, 2005 Report Share Posted December 10, 2005 do u need to bash em out with a hammer? Link to post Share on other sites
RIX 0 Posted December 10, 2005 Report Share Posted December 10, 2005 if you make it flat it will give,don Link to post Share on other sites
ingham 5 Posted December 10, 2005 Report Share Posted December 10, 2005 do not hit it with hammer,i am quite strong and it was hard to remove but i did get it out in one piece Link to post Share on other sites
cadguy77 0 Posted December 10, 2005 Report Share Posted December 10, 2005 it's held in with a little screw chaps Link to post Share on other sites
stuey 0 Posted December 11, 2005 Author Report Share Posted December 11, 2005 That would make it hard to get out !lol Link to post Share on other sites
fritzenberg 3 Posted December 11, 2005 Report Share Posted December 11, 2005 this is the cone thing we`re talkin about,where my hand is in the pic??tried again today to get the bloody thing out,still no joy,i don`t see any screws holdin it in btw,is it glued in? Link to post Share on other sites
RIX 0 Posted December 11, 2005 Report Share Posted December 11, 2005 there are a couple off,bumps that hold it plus some glue,try getting a skrewdriver in between where the maf goes,and wikkel it the hole way around,the you can push i out with a skrewfriver where our little finger is. Link to post Share on other sites
cadguy77 0 Posted December 11, 2005 Report Share Posted December 11, 2005 sorry mis-led on the screw thing, thought you mean't the air intake pipe on the other half (bottom) of the air box Link to post Share on other sites
SankysVR6 1 Posted December 12, 2005 Report Share Posted December 12, 2005 Try squirting some fairy liquid down the cone side, And use Flat scredriver to push the lugs out.Theres been a post about this before try doing search you might the answers your looking for. Link to post Share on other sites
Buzzark 0 Posted December 12, 2005 Report Share Posted December 12, 2005 It's just tight - I took mine out yesterday how topical!There's a long lug underneath it that it slides along (lol - slide isn't exactly right) and a couple of dome bits at quarter to and quarter past that press against the sides to grip it in place.Lube these 3 bits and it should come our fairly easily - washing up liquid is probably best as it's easiest to clean up afterwards - DO NOT use silicone which would otherwise be perfect or your lambda sensor will die. Link to post Share on other sites
fritzenberg 3 Posted December 12, 2005 Report Share Posted December 12, 2005 what does it sound like when it`s out anyway,not loudenough for the cops to give u any grief i hope? Link to post Share on other sites
SankysVR6 1 Posted December 13, 2005 Report Share Posted December 13, 2005 To tell you the truth i didn't notice much difference in the sound. Link to post Share on other sites
Buzzark 0 Posted December 13, 2005 Report Share Posted December 13, 2005 Yeah, not much difference above standard. It'll depend more on what filter you fit inside the box the paper filter I've put in for now makes it very quiet. Link to post Share on other sites
