p1vsg 0 Posted December 22, 2005 Report Share Posted December 22, 2005 hi guys,recently i have noticed my car revving up quicker above the norm. as i plant my foot right down the revs seem to shoot up about 800 - 1000 when im driving at low revs but performance doesnt seem to respond straight away, almost as if there is a lag. does this seem like symtoms of a wearing out clutch?if so what clutch wwould be reccomended as my car engine is standard and wont be charged until at least a year.thanx in advancepiv Link to post Share on other sites
MrBen 0 Posted December 22, 2005 Report Share Posted December 22, 2005 Sounds like it could be. To double check if it is slipping, drive along at about 30 in 5th, drop the clutch, rev the engine to say 5,000 and then let the clutch back in sharpish. The revs should drop straight away. If it doesn't it's slipping.The standard VR clutch is pretty meaty, so unless you anticipate doing a lot of engine mods, go for a stock one. Just make sure it's a proper OEM part, not a cheap copy. Link to post Share on other sites
p1vsg 0 Posted December 22, 2005 Author Report Share Posted December 22, 2005 cheers 4 your help much appreciated. i take it that the stealers will b da only place 2 get an oem part?do you know of any other places? Link to post Share on other sites
mightyvr6 0 Posted December 22, 2005 Report Share Posted December 22, 2005 Agree with MrBen, buy a standard clutch from A VW dealer. These cheaper ones from eurocarparts and gsf are not up to VW quality. Link to post Share on other sites
Snedboy 0 Posted December 22, 2005 Report Share Posted December 22, 2005 Just though ide post my view on this.I bought a clutch from a company called Techniclutch.It's a British company with VERY competative prices.The problem being i bought it for my RS Turbo transplanted Orion and i'm not sure i9f they actually do VW.I paid bout Link to post Share on other sites
Eat this 2 Posted December 22, 2005 Report Share Posted December 22, 2005 i got a sachs kit for about Link to post Share on other sites
matth76 1 Posted December 23, 2005 Report Share Posted December 23, 2005 I've been told that an organic clutch is a good upgrade if you want big power in the future. Not sure how much they are. Link to post Share on other sites
p1vsg 0 Posted December 23, 2005 Author Report Share Posted December 23, 2005 cheers for all the feedback guys Link to post Share on other sites
FishWick 21 Posted December 23, 2005 Report Share Posted December 23, 2005 I am Mr Clutch. I've had 3 warranty replacements on mine which caused Vince at Stealth problems with his suppliers.Reason being each of those 3 kits juddered after a month's use and they were SACHS and LUK kits from GSF. They couldn't see what the problem was, but there was one.....The OE VW kit is a LUK. The kits they and SACHS supply to the likes of GSF just isn't up to the same standard as OE spec. If you put a GSF LUK next to a VW LUK, the differences are obvious. On the VW kit, the pressure plate springs are ground down to form a 100% flat and true mating surface for the release bearing. The GSF kit isn't and can cause juddering.My 4th replacement was a VW kit and hasn't juddered once in 20,000 miles use so far.I'd also recommend a new flywheel from VW. Link to post Share on other sites
apd 0 Posted December 25, 2005 Report Share Posted December 25, 2005 have the helix clutch.bit pricey at 279quid,but copes very well with the power. Link to post Share on other sites
