Crystal lights - fitting
Am going to be fitting crystal fogs and indicators over the next week or so. These should be pretty straight-forward, but any guidance appreciated. Also fitting MK 4 look crystal headlights. Has anyone got any advice on fitting these ref. getting alignment as close as possible, or is is easier taking them to local MOT centre and getting them to line them up?
Regards, Aboo! !alien
  • 3 weeks later...
With the fogs and indicators make sure youve got two screw drivers a smaller one and a medium sized.
Pretty straight forward pop the indicator out from the side nearest the fog.
Then unscrew the fog light and remove. replace fog first then clip in indicator.
Headlights i think you need to take the grille off then get them setup at an MOT place if you want.
