Pete.sVR6 0 Posted May 3, 2004 Report Share Posted May 3, 2004 Hi allI have started to get a slight misfire from cold, more severe when slowing/accelerating at junctions etc, this goes away,as the engine warms up. I have yet to get the car diagnostic checked. any ideas? VW approved garages in the Oxfordshire area anyone?Cheers. Link to post Share on other sites
Eat this 2 Posted May 3, 2004 Report Share Posted May 3, 2004 i had exactly the same thing 1 of the plug leads had come off the plug so at cold tickover and v light throttle it was missin but with more throttle it arced to the plug and worked its worth a look Link to post Share on other sites
28v6r 0 Posted May 3, 2004 Report Share Posted May 3, 2004 Have you carried out the standard tests on the coil pack, leads etc? i.e spraying the coil pack in light water? checking for arcing?When were the plugs last changed?The first one is a relatively easy fix, buy some silicone grease and coat the coil pack, Silicone acts as an insulator and should cure any misfire, next remove all leads and place in oven at Gas mark three.... Seriously, give the leads a reasonably warm heat but not VOLCANIC then leave in oven for 15-20 mins until hot to the touch, remove from oven and spray liberally with WD40 or similar and allow to dry then refit and Aye Voila!!!! No more misfire!Regards28v6r Link to post Share on other sites
Eat this 2 Posted May 3, 2004 Report Share Posted May 3, 2004 nice 1 delia 28v6r lol il write that down sounds v usefull Link to post Share on other sites
28v6r 0 Posted May 3, 2004 Report Share Posted May 3, 2004 Ahhhhh... but you haven't seen me in my pinnie, working on the VR You may remember a cook in the 70's called "Fanny" errmm ...ehhh ....errrm.. Awwww bo***x! anyway that could be said for what I do to a VR! !amazed Link to post Share on other sites
Pete.sVR6 0 Posted May 3, 2004 Author Report Share Posted May 3, 2004 Cheers, for the advice, I have sprayed the coilpack and leads with wd40, and today the car ran fine, did have the bonnet up when i started it, heard a cracking noise (arching maybe?) a couple of times, but this didn't seem to correspond with any misfire? I have looked closely at the coilpack looks very clean like it may have been replaced at some point, so maybe my problem is the leads or plugs, car has a FSH so I assume they have been replaced at the correct intervals, As already explain I will be getting the car diags checked so will see what else if anything is going on &| ? Link to post Share on other sites
patrick green 0 Posted May 4, 2004 Report Share Posted May 4, 2004 Pete does it ever feel a bit sluggish as you change up? As if the engine loses something just for a second or two? I had that & it was a camshaft sensor. Put a new one on & it went away Link to post Share on other sites
Pete.sVR6 0 Posted May 4, 2004 Author Report Share Posted May 4, 2004 Patrick,I can't say I have noticed that, touch wood, the problem has gone away (for now?) fingers crossed I will get through the 'Inters' weekend, and then I can concentrate on getting the car looked at properly.Cheers. Link to post Share on other sites
patrick green 0 Posted May 4, 2004 Report Share Posted May 4, 2004 Good luck then Pete! btw AMD are in Bicester if thats of any help! Link to post Share on other sites
Pete.sVR6 0 Posted May 5, 2004 Author Report Share Posted May 5, 2004 Why didn't i think of that!! believe it or not they are about 2 mins away from me, was thinking of suitable VW garages not tuners, Doh !amazed Link to post Share on other sites
