GREGORY 0 Posted January 19, 2006 Report Share Posted January 19, 2006 Looking to buy a vr6 and have a couple of questios as is no buying guide that i can find on the net.1-Which vr's have air con2-is there a changer over year3-what common problems should i look for4-what is the average mpg not that it matters in this country what you drive they still have your pants down ~ ~( 5-whats the insurence group,and do they come with alarms?thanks Link to post Share on other sites
purple highline monster 0 Posted January 19, 2006 Report Share Posted January 19, 2006 Q,1 Highline vr6`s come with aircon, a lot of other cars have it as an option and also leather, (highlines have highline written on the log book and unless its purple or black its not a highline)Q,2 change over year is 1995 around N plate you can tell a later spec car buy oval wing repeaters and no wheel arch trim and completely body coloured trim and bumpers, it should also have an obd2 version engine slight differences to earlier type (some early highlines have the square wing repeaters though!) just to confuse the issue!Q,3 most issues are the same as other car buying guides, just check all the panels and mechanicals as best you can, some high mileage vr6`s can have rattly timing chains (very expensive to change upto £800 at a garage) and poor running or misfires if not looked after, head gasket and water pumps are things to look for signs of failure, if it looks abused dont buy there are loads about!Q,4 average mpg is from 15 upto 35 mpg on a good run depends how and where your driving! ive had mine as low as 11 mpg!! depends how heavy your right foot isQ,5 insurance on normal vr6 is group 17 the highline is group 18 due to full leather and extras on itQ6 most vr6 came with a factory logic 900 series alarm, although most will have some sort of aftermarket one if not, make sure you get both alarm fobs if its a logic one as you need a master and slave, master has white coloured led that illuminates red slave just has red led on fob, the immobiliser on them is part of the igniton key system and ecu so you have to retain it!! there is a comprehensive buyers guide on here but is only open to premium members, i am sure if your search around lots of your questions will be answered already in the forum posts, this is not a definitive guide and i am sure it will be added to by other members but i hope this helps a bit Link to post Share on other sites
craggsy 91 Posted January 19, 2006 Report Share Posted January 19, 2006 1. Highlines had it as standard but mine aint a Highline and has climate, so look around2. 1995 went from OBD1 to OBD2 and galvanised body i think3. Rattling chains and rust in early cars4. Never really bothered about that but about 28-30mpg if your light footed5. 16 or 17 i think Link to post Share on other sites
GREGORY 0 Posted January 19, 2006 Author Report Share Posted January 19, 2006 Thanks mate,thats what i needed to know and more .you know your sh*tCheers !lol Link to post Share on other sites
vdubgirl 3 Posted January 19, 2006 Report Share Posted January 19, 2006 Lots of info on this thread http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?40042 Link to post Share on other sites
