I need to replace both my front and rear disks soon and i'm looking for recomendations please? My car is and early VR so has the smaller disks - would it be worth getting a conversion kit to get bigger disks? What from?
Thanks in advance! :D
audi tt discs?315mm dia.i'm thinking of doing that route!think standard,ie.not grooved or drilled are about £70.00 from ecp?then either make some brackets for your old calipers,or better still,grab yourself some tt calipers?????just a thought!
if you don't overheat your brakes (get brake fade) get the proper ones from your vw rip off merchant.
uprated stuff is not good when cold, si if you don't need to handle extra heat, theres no point sacrificing cold performance.
standard brakes on a vr are getting close to near shit in performance!ever wondered why the later mk3's have slightly bigger discs?bigger diameter discs surely work better than smaller?!?!?!granted i'm not a fan of discs with grooves or drillings.however,if you put braided hoses on,and a set of tt calipers and discs,i'm sure they must be as progressive as oe brakes,and as for warming up,you can't have performance without sacrificing a little warming up period eh????i know what i'd rather have stopping me!i'll keep you posted on my 315 mm disc conversion(compared to my 280 discs at present!)
