help konigsports
I had my kongsports fitted to my mk3 vr6 and i have been playing with the ride height ,but the front left has only about 13 mm thread left and the front drivers side has 29mm left. i have measured the centre of the wheel to the top of the arch and its the same ,is this normal . It drives fine . :?: :?:
dunno if FK do this for a reason? but most standard VW suspension has an extra 10mm clearance on drivers side to allow for the weight of the driver! i found i had to have my FK coilovers set slightly higher on the drivers side anyway to compensate as i am quite a big built roughty tufty rugby chap ;) just make sure you dont go mad on the slam as this can affect the tracking and camber settings if they were done when it was higher :|
Ahh i see ,i have it quite low ,so the top of the tire is about level with the inner top wheel arch (think this makes sense lol) Im ok with most speed humps.
I have it booked in for 4 wheel alighment saturday ,but say if i need to ever raise the height 10mm allround would this cause camber traking problems ?
thanks Mark
Well been adjusting again and can now get only 1 finger between the arch and tire.Have yet to test drive it but im sure it will be ok,will try tommorow.
Cookie waht wheels are you running on yours as those tt wheels look great ,i had a set of kekins on my corrado but they were corroding super fast.
