A tapped ABS light should have failed the MOT! Unless you made it look like there was no ABS at all.
My suggestion' date=' which I'm likely to use on my valver, is to disconnect the ABS lamp and bridge across from the Airbag warning lamp.
Lamps come on, Lamps go off, Lamps come on, Lamps go off...
TG
That is exactly what I did when the ABS pump on my old VR6 stopped working. I simply poked the bulb for the airbag light through the hole for the ABS light, then taped the circuit board into place. The airbag system is NOT checked on an MOT and the airbag light behaves exactly as the test expects the ABS light to behave.
Worked for me too :D Passed first time :D, after £150 !sad of silencer a few weeks ago anyway
TG
  • 1 month later...
