[moved] Gear selection
Gear selection went all to pot today and i had no reverse gear and first is where reverse is and second is below it in a new position and i have at least three third gears so it was straight to the garage with it and the said it will be some bush or other but i will keep you lot posted!!
hmm, i just had a new box fitted, and i have to force the stick to the left to get reverse, 1st and 2nd. do the 02A's have a selector plate? cos i think a garage has put it in wrong, lol. ill have to keep an eye on this thread to see what the deal is n get that bush replaced
Right ,on top ov gearbox where linkage is there is a wierd shape black L shaped piece ov cast or some sort ov metal anyways its held on by 1 bolt 13mm i think if this bolt overtightened or replaced with wrong bolt causes this problem undo bolt and put a washer or 2 in then try gears again this worked for me as teh bolt scratches on top ov box and causes probs with rev 1st n 2nd
I would think a garage would be your best bet as it only took my garage 1/2 an hr to fix! And six appeal i don't know what caused it to go but the car had been standing still with the engine running before i set off only to find my gears were all to pot but seems good now!!
  • 2 years later...
