petervr6 0 Posted March 1, 2006 Report Share Posted March 1, 2006 ok normal driveing its perfect but if i go up to 5000rpm then changing gear quick it seems to sorts of rev on the spot for a sec or two is this normal if the clutch was slipping wouldnt it do it all the time or would it do it under load. Link to post Share on other sites
kilokilla 0 Posted March 1, 2006 Report Share Posted March 1, 2006 have known them to do it all different ways depending on which part of clutch is going mate it does sound like yours is starting to go if its revving a little before it bites Link to post Share on other sites
petervr6 0 Posted March 2, 2006 Author Report Share Posted March 2, 2006 how much labour have people payed for for this going by i supply the clutch? Link to post Share on other sites
kilokilla 0 Posted March 2, 2006 Report Share Posted March 2, 2006 well i charge £175 supplied and fitted and thats with sachs clutch which i find to be better quality than most. Link to post Share on other sites
petervr6 0 Posted March 4, 2006 Author Report Share Posted March 4, 2006 good price pitty you so far as im not feeling likedoing thisme self prob worth gettin the chains do as well while the gbox is out. Link to post Share on other sites
kilokilla 0 Posted March 4, 2006 Report Share Posted March 4, 2006 if your car has done around 100k its well worth getting chains and tensioners done at same time will save you loads in the long run. Link to post Share on other sites
dubberVR6 0 Posted March 6, 2006 Report Share Posted March 6, 2006 kilokilla, how much would you charge for that? I'm not too far! Link to post Share on other sites
Eat this 2 Posted March 6, 2006 Report Share Posted March 6, 2006 he did mine (amongst other things) and il vouch for his work Link to post Share on other sites
