Might be your water pump bearing mate. Thats the only bearing I can think of apart from the bearing in the alternator. Try taking the belt off and running it , if the noise goes away after doing this it will be one of the two i would have thought. Then again, I could be completely wrong.
Sorry mate, I haven't done either , YET anyway. They don't look to bad to get at, sure someone will be able to tell you. I would think the water pump should be ok if it was done that recently, unless the drive belt has been over tightened, which will knack your bearings a lot quicker.
