fatboy-slim 0 Posted May 12, 2004 Report Share Posted May 12, 2004 Hi, hope someone can help, i have just changed the disc and pads front & back everything went ok but when i started the car the abs light go's off and then comes back on and stays on.If that is not bad enough i was pulling away from some traffic lights today and the abs started to kick in front left then right just for a split second.Anyone got any ideas ,have got a feeling this is going to cost me. Link to post Share on other sites
six appeal 53 Posted May 12, 2004 Report Share Posted May 12, 2004 Think you may have dislodged one of the sensors when you have been doing the pads or at least got one of them dirty.They have a habit of being very vunerable, so take the wheels back off and give them a good check and clean, see if this works, if not one may be on its way out! Think they are only about £50 from GSF. Link to post Share on other sites
gazbrook 0 Posted May 12, 2004 Report Share Posted May 12, 2004 i have a dodgy wheel speed sensor on my car and have a permanent abs light on ,the front ones are about £65 each and the back one about £35 from gsf,thats on my to do list when i get my car back,if you can't see which one it is a diagnostic machine should be able to tell you Link to post Share on other sites
antera309 3 Posted May 13, 2004 Report Share Posted May 13, 2004 Yes, sounds like a sensor problem. Check that the ABS sensors are fitted properly and haven't come loose. Check cabling to the sensors too. Give them a clean too if you can. Link to post Share on other sites
fatboy-slim 0 Posted May 13, 2004 Author Report Share Posted May 13, 2004 Thanks for the help i will have a look at the sensors at the weekend hope i can just clean them up. Link to post Share on other sites
fatboy-slim 0 Posted May 15, 2004 Author Report Share Posted May 15, 2004 Ok i have cleaned the sensors, wot a pig to get out and everything seems to be ok for now (no abs light) will let you know if there is any change.Thanks for the help !amazed cheers fatboy.. Link to post Share on other sites
VR6Steve 0 Posted May 15, 2004 Report Share Posted May 15, 2004 Fingers crossed that the light stays out. Link to post Share on other sites
fatboy-slim 0 Posted May 15, 2004 Author Report Share Posted May 15, 2004 I hope so looks like the back one's would be easy to change but front look like trouble.Fingers crossed i will not need too. Link to post Share on other sites
