Guest Smokey Dog Posted March 9, 2006 Report Share Posted March 9, 2006 And if not, how can you tell?Currently weighing up buying a 'Rado or Golf VR but want to make the right choice.... Will be looking for 200bhp+ out of it which I know is a little easier with the 'Rado but for the £k mark they all seem to be massive milers !sad whereas the Golfs are pretty reasonable. The 'Rado is the much nicer looking but I could pick up a much newer Golf.... decisions, decisions... Link to post Share on other sites
purple highline monster 0 Posted March 9, 2006 Report Share Posted March 9, 2006 rado is dearer and less comfortable too! golf is easier for mods an tinkering with imo Link to post Share on other sites
Guest Smokey Dog Posted March 9, 2006 Report Share Posted March 9, 2006 I'm definitely a DIY type person. I don't have much technical knowledge but will always attempt something, armed with a Haynes manual if I think i can do it. Link to post Share on other sites
Seademon 0 Posted March 9, 2006 Report Share Posted March 9, 2006 Golfs newer than an N reg are usually OBD2 - any engine with a distributor will be OBD1.All VR6 Corrado's are OBD1. The OBD2 engines have slightly more power.I'd go for the Golf but i am biased! Link to post Share on other sites
SankysVR6 1 Posted March 9, 2006 Report Share Posted March 9, 2006 Not all highlines are ODB2 there was lad on here called Nerih that had ODB1. Theres a sticky in the mechanical section which tells you how to tell the difference. Link to post Share on other sites
Seademon 0 Posted March 9, 2006 Report Share Posted March 9, 2006 Nerih's is an N reg I think too so to answer your question correctly, no - not all Highlines are OBD2 :0) Link to post Share on other sites
Slim 0 Posted March 9, 2006 Report Share Posted March 9, 2006 To confuse matters, I've got a 96 N plate that is OBD2. Link to post Share on other sites
Al J 0 Posted March 9, 2006 Report Share Posted March 9, 2006 I have got a N reg highline (registered August 95). Judging by the throttle body and square side repeaters, it is OBD1, yet it has a 288mm brake set up rather than 280mm.I am guessing that this was right at the crossing point between OBD1 & 2 Link to post Share on other sites
tinny22 11 Posted March 10, 2006 Report Share Posted March 10, 2006 my highline was a N reg obd1 with 288mm brakes and my vr is not a highline oct 95 n reg and is obd2tinny22 Link to post Share on other sites
Eat this 2 Posted March 10, 2006 Report Share Posted March 10, 2006 they changed in mid 95 there is the odd obd1 highline the easiest way to tell is the side repeaters theyr square on obd1 and oval on obd2 Link to post Share on other sites
matth76 1 Posted March 10, 2006 Report Share Posted March 10, 2006 Aren't they orange too on the odb1's whereas whitish on odb2? Link to post Share on other sites
