jonnyedinburgh 0 Posted March 9, 2006 Report Share Posted March 9, 2006 I've managed to bust the little ear washer jet nozzle (the little bit with the pin hole in it that washer fluid comes out of). How do i replace this part as i am a bit tired of having a filthy rear window. thanks Link to post Share on other sites
SankysVR6 1 Posted March 9, 2006 Report Share Posted March 9, 2006 just had a look on ETKA and it looks the washer jet nozzle is attached to the motor. Link to post Share on other sites
jonnyedinburgh 0 Posted March 9, 2006 Author Report Share Posted March 9, 2006 I think you're right. i've looked a bit closer by removing the black plastic cover and it looks like the nozzle is attached directly to the motor assembly. i hope this part can be replaced without having to replace the whole motor, you'd think such a small item would be easy to replace! Link to post Share on other sites
jonnyedinburgh 0 Posted March 9, 2006 Author Report Share Posted March 9, 2006 just sourced the part from the main dealer. the nozzle and tube come as part of a kit and cost about £4.00, not bad and they will have it in for tomorrow. Link to post Share on other sites
thegoth 5 Posted March 9, 2006 Report Share Posted March 9, 2006 The nozzle should just pull out from the outside using a pair of mole grips. When mine was blocked I took all the inside trim off before realising.TG Link to post Share on other sites
francisjonno 2 Posted March 10, 2006 Report Share Posted March 10, 2006 This is a bit of a nightmare job unless you've got enough of the old nozzle left to pull on with mole grips.Make sure spary some wd40, or similar, and let it soak in, to help loosen it b4 you start pulling.I ended up having to remove the motor and drill out the old nozzle :@ Link to post Share on other sites
jonnyedinburgh 0 Posted March 11, 2006 Author Report Share Posted March 11, 2006 sorted this afternoon. screwed a small screw into the hole of the broken nozzle and pulled it out with mole grips. that was easy. it was harder putting the new nozzle in it only goes in so far at first then you have to tap it home gently with a small pin hammer. sorted Link to post Share on other sites
