not totally sure on this but you should be able to just disconnect the passenger airbag from the back of the airbag and from the airbag ecu which is located in the area under heater matrix in centre of bottom of dash basically just to the left of clutch pedal behind the plastic casing that covers the exhaust tunnel .
