sparkz 0 Posted March 16, 2006 Report Share Posted March 16, 2006 Where can i get the above item from guys? ive spoken to my Vag dealer and they have no listing for it. Has anyone got a part code for me? I believe they came on the early mk4 v64motions?CheersPatrick Link to post Share on other sites
dubloke 4 Posted March 17, 2006 Report Share Posted March 17, 2006 try here patrickhttp://www.c2motorsports.net/ss_headgasket_spacers.asp Link to post Share on other sites
RIX 0 Posted March 17, 2006 Report Share Posted March 17, 2006 no there from the us vr6,the car we don´t have over herei have one at home brand new,i did´nt use cause the mekanicsaid my block wasn´t flat enough.can´t find the number here by the comp so will go and have a look later. Link to post Share on other sites
dubloke 4 Posted March 17, 2006 Report Share Posted March 17, 2006 doesnt matter a head gasket is a head gasket fella, and there is no difference in blocks or head on us models compared to uk models. you've been misinformed i'm afraid! how can your block not be flat enough? have asked the question myself and they defo fit! Link to post Share on other sites
RIX 0 Posted March 17, 2006 Report Share Posted March 17, 2006 Dubloke,by flate enough i ment like when the head is skimmed,my blok wasn´t skimmed thats why wee didn´t fitt itit needs too be,cause with a metal gasket it´s diff. to seal it corretli,and the gasket is from a mrk. vr6 a car that is not made for the eu only us that´s why,or have you seen any vr6 mrk. 4 from 2000-2001.the metal gasket raises the comp. to around 11:1 insted off 10:1 Link to post Share on other sites
dubloke 4 Posted March 17, 2006 Report Share Posted March 17, 2006 well, the gasket supplied to me was identical to a new vw one so i guess i must have a mk4 24v engine in mine. always wondered why it seened quick for an obd1. i'll have to ring chris at c2 back and let him know not to send any more over to the uk! Link to post Share on other sites
katconcarne 0 Posted March 17, 2006 Report Share Posted March 17, 2006 so you'd recommend that head gasket then dubbloke?! i'm planning on changing mine as i've noticed some leakage, i'll be getting it skimmed while i'm at it, is it the one that's $175 that you got?Thanks dude, Kat Link to post Share on other sites
dubloke 4 Posted March 17, 2006 Report Share Posted March 17, 2006 yeah, just give chris a ring or an email and he'll sort you out! tbh, there is no real need to use a metal gasket unless you are going FI route, which i am. will be using arp bolts to fasten it down too so no leakage for me! Link to post Share on other sites
DUB50K 0 Posted March 17, 2006 Report Share Posted March 17, 2006 Metal Headgaskets avaialable from here aswell...http://www.spturbo.com/mainpages/parts/vr6headgasketsspacers.htmKeith13:55 Update to link! Link to post Share on other sites
mk3anni 0 Posted March 17, 2006 Report Share Posted March 17, 2006 yeah' date=' just give chris a ring or an email and he'll sort you out! tbh, there is no real need to use a metal gasket unless you are going FI route, which i am. will be using arp bolts to fasten it down too so no leakage for me![/quote']Matts been saying this for the last year....i'll have my charger on before he does!!!! Link to post Share on other sites
dubloke 4 Posted March 17, 2006 Report Share Posted March 17, 2006 but at least mine will be done right, and besides, you'll have blown yours up shortly after i've passed you on route to a show! lol. Link to post Share on other sites
VR6Pete 1,455 Posted March 17, 2006 Report Share Posted March 17, 2006 naughty mathew, replying to a thread thats in the wrong forum section! I'll move it then..... Link to post Share on other sites
dubloke 4 Posted March 17, 2006 Report Share Posted March 17, 2006 sowwy, got a little side tracked there! Link to post Share on other sites
mightyvr6 0 Posted March 17, 2006 Report Share Posted March 17, 2006 Got to me careful if you are using the correct metal headgasket (ie not the US mrk 4 12v gasket) with a supercharger/turbo as you don't want to raise the compression ratio. Link to post Share on other sites
mightyvr6 0 Posted March 17, 2006 Report Share Posted March 17, 2006 You want to lower the CR if anything not raise it! Link to post Share on other sites
dubloke 4 Posted March 17, 2006 Report Share Posted March 17, 2006 wise words indeed ben! Link to post Share on other sites
mightyvr6 0 Posted March 17, 2006 Report Share Posted March 17, 2006 Needs someone to post up part nos for the US mrk 4 12v vr6 metal headgasket and the UK vr6 12v metal headgasket to show if they are indeed different. Link to post Share on other sites
RIX 0 Posted March 17, 2006 Report Share Posted March 17, 2006 i bought mine from vw in flensburg,they said they don´t have one listed for the mark.3,so i gave them the number i got true here,and payed a maximum of 80 euro for mine.if there is interest i could order a few and send them over,since you guys pay 175 dollars thats around 154euro´s for them true the stats. Link to post Share on other sites
IbiVR 0 Posted March 17, 2006 Report Share Posted March 17, 2006 12v VR golfs in the UK are AAA code and came with the crap paper gasket. Later VR's are AMY code and have the 3 layer metal gasket. I dont think the AMY came in any UK golfs, but it did come in other stuff.Namely a 1996 Sharan VR6 - AMY engine code. part numer for the metal gasket is 021 103 383N, and it will fit any UK 12v vr.As for being flat enough, if your block/head aint flat then no gasket is gonna fix that. Metal one will be fine unless somethings gone horribly wrong.....If you get stuck getting hold of one let me know and i can get it to you for about £55 plus delivery if i remember.These are std vw gaskets of course, so not suitable for fi use without a spacer to drop compression - as mentioned by mightyvr6.Tom. Link to post Share on other sites
sparkz 0 Posted March 17, 2006 Author Report Share Posted March 17, 2006 Namely a 1996 Sharan VR6 - AMY engine code. part numer for the gasket is 021 103 383L i think' date=' and it will fit any UK 12v vr.[/quote'] Ive got 2 of these already in my front room!! (paid £50 for the pair...contacts in vag parts!! ) However, i am planning on lowering the compression in the proper way and i would like to get a standard metal head gasket (if poss) instead of the standard vag one (just for piece of mind). The spacer gasket i will not need as i dont want to lower the compression any lower. Link to post Share on other sites
Guest Suti Posted March 19, 2006 Report Share Posted March 19, 2006 http://www.autotech.com/prod_engine_headgaskets.htm#vr6sport Link to post Share on other sites
Lizard Racing 0 Posted March 19, 2006 Report Share Posted March 19, 2006 Any idea of the compression with the AMY metal gasket (021 103 383N)? Link to post Share on other sites
IbiVR 0 Posted March 19, 2006 Report Share Posted March 19, 2006 Not offhand - but i think its about 0.3 up on the paper one. Link to post Share on other sites
apd 0 Posted March 20, 2006 Report Share Posted March 20, 2006 got a copper spaced head gasket from stealth for s/c mk3 golf.CR is 9;1.with an 8.5psi pulley. Link to post Share on other sites
sparkz 0 Posted March 22, 2006 Author Report Share Posted March 22, 2006 Just to confirm, ive spoken to vag and they cant confirm that 021 103 383N is the same as 021 103 383L (standard head gasket) Can someone please tell me if they are exactly the same pattern.Cheers Link to post Share on other sites
