Part number required - Corrado Fuel Pressre Reg.
simon - you are spot on - i've just found out - very late model golf vr's had a different pressure reg - part number 037 133 035C...
later model vr's have a 3bar fuel pump
early model ones have a 4bar pump
the regulator is different accordingly (obviously)
if your chassis number is wvwzzz1HZTW360000 or before you will have the higher (4bar) regulator already...
cadders - you have the higher pressure one already . . . :(
Do you know if they have a different rated fuel pump too Richie? Hopefully my pump can easily supply 4 bar?
Simon.
yours will have a 3 bar pump as std...
i doubt it will even be able to supply 4 bar as it wasn't designed to
there is a 4 bar one for earlier vehicles, which had fitted a 4 bar regulator from factory -
it's number is - 1H0 919 651Q but it's not cheap . . .£134!!! !amazed !amazed
working in the piping industry, pumps are always capable and have a greater deisign pressure then working pressure. So if the regulator keeps the system at 3 bar the pump must provide a higher pressure.
Can you find out for sure please Richie?
