Caddyslammed 16 Posted March 23, 2006 Report Share Posted March 23, 2006 I have recently fitted a new oil pressure switch to solve an oil leak which it has done so, but i have another oil leak, i have taken a picture to illustrate it, the view is the underside of the oil cooler, please suggest thoughts on what the likely problems could be? thanks. Link to post Share on other sites
apd 0 Posted March 23, 2006 Report Share Posted March 23, 2006 new set of O rings from the dealer,common prob.but do it when engine is cold.about a tenner IIRC. Link to post Share on other sites
Caddyslammed 16 Posted March 23, 2006 Author Report Share Posted March 23, 2006 bloody pain in the arse ennit!, i suppose it will be quite simple to change? a bolt on the front, and when up on ramps it will be easier, also it is above the oil level so shouldnt loose too much oil? Link to post Share on other sites
57ORM 0 Posted March 24, 2006 Report Share Posted March 24, 2006 I have the same problem will try and tackle it this weekend.Thanks Link to post Share on other sites
apd 0 Posted March 24, 2006 Report Share Posted March 24, 2006 straight forward job jacked up/ramps.no oil loss as the sump is lower than the cooler.make sure the engine is cold.10 min job. Link to post Share on other sites
Caddyslammed 16 Posted March 24, 2006 Author Report Share Posted March 24, 2006 why do you say the engine needs to be cold? it could be tricky as i need to travel 20 miles to the ramps? i dont mind losing some oil , and i will take some with me. Link to post Share on other sites
apd 0 Posted March 25, 2006 Report Share Posted March 25, 2006 try putting your mits on the alloy housing when your engine has been running!you'll end up with kebab hot fingers!ps gloves might help! Link to post Share on other sites
Caddyslammed 16 Posted March 25, 2006 Author Report Share Posted March 25, 2006 the seals are now done, bit fiddly to get the cooler to block o ring in perfect place, but hopefully done now, thanks for all your help Link to post Share on other sites
jloppy1 0 Posted March 26, 2006 Report Share Posted March 26, 2006 Hi i need to replace my oil cooler rings also. Can you tell me what parts i might need to remove to get access to the cooler if any? and are there any potential problems i might have?cheers Link to post Share on other sites
Caddyslammed 16 Posted March 26, 2006 Author Report Share Posted March 26, 2006 hi jloppy1, here is an underside pic of my sorted cooler, i chose to use my friends four poster ramps, much easier than using a jack etc, i think it is only possible from below although you could loosen the bolt from above to start with, it is only one big bolt through the cooler into the block, it has the black plastic on it at the front of the cooler, it should not be tight, or at least it should not be done up to tight when re tightening, it hes the torque written on it, when i loosened the bolt about a small glass worth of oil came out, but my engine was hot, the seals are either side of the cooler, one round oring with the square edges is in the plastic bolt part, and the rounded oring with the ears goes between the cooler and the block, when you have the old ones out compare them to the new ones and you will probably see why it was leaking! clean everything off really well for the seals to work and replace as they came out, the cooler to block one can be a bit tricky but you know when you have got it in there correctly, anything else you want to know ask mate. Link to post Share on other sites
jloppy1 0 Posted March 26, 2006 Report Share Posted March 26, 2006 Hey caddyslammed Thanks for that info i have been putting off tackling this job for a while now. But after your response i think i,ll be down the stealers tomorrow to get the seals. hope they have em in stock.Cheers again mate Link to post Share on other sites
Caddyslammed 16 Posted March 26, 2006 Author Report Share Posted March 26, 2006 no probs, should be about £5 for both, thats what i paid Link to post Share on other sites
57ORM 0 Posted April 1, 2006 Report Share Posted April 1, 2006 Changed mine today thanks to all for the adviceFinished the job and left the car running for 20mins checking my handy work !lol then found collant dripping from thermostat housing x) and a split CV boot ~ Link to post Share on other sites
johnemerson38 1 Posted April 15, 2006 Report Share Posted April 15, 2006 hi just wanted to no what the things is under the oil cooler with the wire attatched to it is in a knock sensor or something also what do i use to get it off Link to post Share on other sites
