Caddyslammed 16 Posted March 23, 2006 Report Share Posted March 23, 2006 The vr i have now has only done 5000 miles in the last 6 or 7 years and it is giving me problems!, can anyone tell the part in the picture which is leaking coolant so i can get a new one?, thanks Link to post Share on other sites
dellert 0 Posted March 23, 2006 Report Share Posted March 23, 2006 Unless I am very mistaken it looks like the Auxillary water pump, i am sure i will be corrected if that is not the case. Is it near the coil pack under the silver plastic cover that the HT leads run in? Link to post Share on other sites
Caddyslammed 16 Posted March 23, 2006 Author Report Share Posted March 23, 2006 i think you are correct dellert, as you look at the front of the engine it is at the back right Link to post Share on other sites
dellert 0 Posted March 23, 2006 Report Share Posted March 23, 2006 GSF do a Bosch one for a good price, Bosch is the same as a genuine one. Link to post Share on other sites
Caddyslammed 16 Posted March 23, 2006 Author Report Share Posted March 23, 2006 ok cheers mate, i will probably get a new hose and clips also if i can explain it to them easily enough. Link to post Share on other sites
Caddyslammed 16 Posted March 23, 2006 Author Report Share Posted March 23, 2006 if i was to search the gsf site for this part, what would i type in? auxilary water pump does not work Link to post Share on other sites
thegoth 5 Posted March 23, 2006 Report Share Posted March 23, 2006 Hi,Cant find it at gsf site. the www.eurocarparts.com number is 201440740: 62.95 + vatTG Link to post Share on other sites
Caddyslammed 16 Posted March 23, 2006 Author Report Share Posted March 23, 2006 thanks goth Link to post Share on other sites
dellert 0 Posted March 23, 2006 Report Share Posted March 23, 2006 cant find it on gsf site either but they defo do them, usually got them on the shelf, got a catalogue with part number if required. probably similar price. Link to post Share on other sites
Caddyslammed 16 Posted March 23, 2006 Author Report Share Posted March 23, 2006 ok cheers dellert, the pump works fine i think, but it is leaking as far as i can tell from a flange at the bottom just above where the hose clips on, maybe it is something simple that i could sort out? Link to post Share on other sites
dellert 0 Posted March 23, 2006 Report Share Posted March 23, 2006 Not sure. Mine leaks a little around the joints on the pump. I asked about it on here too, thought there may be a seal replacement job, but apparently not. If it works it may be worth while stripping it and trying a bit of sealant compound or high temp silicone around the seal. Let me know how you get on, as I gotta do mine as soon as it warms up a bit outside!!! Link to post Share on other sites
Caddyslammed 16 Posted March 24, 2006 Author Report Share Posted March 24, 2006 i have stripped it and redone the seal with silicone, tomorrow will be the day of truth! Link to post Share on other sites
Caddyslammed 16 Posted March 25, 2006 Author Report Share Posted March 25, 2006 seal has held so far, which is nice Link to post Share on other sites
dellert 0 Posted March 25, 2006 Report Share Posted March 25, 2006 Well done mate, saved yourself £70!!!! Link to post Share on other sites
Caddyslammed 16 Posted March 25, 2006 Author Report Share Posted March 25, 2006 so far yes! Link to post Share on other sites
