feltch racing 0 Posted March 27, 2006 Report Share Posted March 27, 2006 ive got abit of a running prob with my k plate vr6 golf, and when i spoke to a bloke last nite at milton keynes he said it could be a relay with 109 wrote on it ??? my car judders like a kangeroo and the clocks all die when this happens i try to give it some revs but i just hear induction noise an no go ??? Link to post Share on other sites
bazz780 0 Posted March 27, 2006 Report Share Posted March 27, 2006 could also be the MAF (air flow sensor)for a quick test unplug it and see if it drives a bit better if it does then could well be your solution Link to post Share on other sites
feltch racing 0 Posted March 27, 2006 Author Report Share Posted March 27, 2006 where is the air flow sensor ? Link to post Share on other sites
richievr 1 Posted March 27, 2006 Report Share Posted March 27, 2006 the "109" relay is the fuel pump one ...it has "109" on the end - visible when you look at the bunch of relays under the dash Link to post Share on other sites
feltch racing 0 Posted March 27, 2006 Author Report Share Posted March 27, 2006 how much can i get a fuel pump relay for and where ? Link to post Share on other sites
richievr 1 Posted March 27, 2006 Report Share Posted March 27, 2006 a 109 relay is £12.91 from vw ....any half decent dealer should have or i can mail order pm me if you want one .... Link to post Share on other sites
Peakz 0 Posted March 27, 2006 Report Share Posted March 27, 2006 When I had a 109 Relay fault my '94 Vento VR just kept cranking and wouldn't start.Only way to start it was to reset the system with VAG-COM.Replaced the relay and because the cam sensor was cheap at £35 I did this too just for peace of mind. Link to post Share on other sites
