Weird Engine noise at 3900-4000 Rpm
Hi,i posted recently about my 1996 vr6 golf making a weird noise at 4000 rpm and everyone who replied said it was tappets however if it was tappets would it not make the noise all the time this noise only happens at 3900-4000 rpm and its like a loud ticking noise whenever the power band comes in however disppears after 4100 RPM any ideas to what this could be as its really annoying me? Maybe it is tappets if so how do you quieten them?
Thanks Richie
A couple of questions...
Does it happen under load i.e in gear?
Or can it be replicated stationary?
If the second, try putting a long screwdriver to where you think the sound comes from and put your ear to the end of the screwdriver and listen ...
Then tell us what you find..
  • 3 weeks later...
sorry to jump in but what is pinking I heard about this a few times and don't have a clue what it means.
My understanding of it is that the knock sensors kick in and retards the map. in some cases it can be audable and heard quite clearly. I can only describe the noise as dropping a load of small nails on a metal surface...
Pete
