disco 0 Posted March 31, 2006 Report Share Posted March 31, 2006 hello people i was just wonderin if anyone could help me find the engine speed sensor (G28) & the Coolant Temperature Sensor (G62) ive had a good look last nite an cant seem to find them. ive got a 1994 vr6. any help would be greatly appreciated. thanks Link to post Share on other sites
richievr 1 Posted March 31, 2006 Report Share Posted March 31, 2006 hi matecoolant temp sensor is just to the right and below the inlet manifold.. they're on the thermostat housing facing the back of the rad..... if you have air con there are 3 switches if you don't there will be 2 and a blank plug...the engine speed sensor is bolted to the lower front part of the block near to the gearbox end with a single allen key .....the connector for it is just by the other sensor ...p.s.this is not my engine unfortunately......thanks to whoever's it is - found on google... Link to post Share on other sites
disco 0 Posted March 31, 2006 Author Report Share Posted March 31, 2006 cheers mate. so r they easy enough to change then. bet you wish that was your engine sure wish it was mine!! Link to post Share on other sites
SankysVR6 1 Posted March 31, 2006 Report Share Posted March 31, 2006 Can i ask why you want to change the speed sensor Link to post Share on other sites
disco 0 Posted March 31, 2006 Author Report Share Posted March 31, 2006 yeah ive had my car put on the diagnostics and its come up that theres no signal coming from the speed sensor or the coolant temperature sensor. an my cars just been a bit off the pace at the mo which is why i had it checked. done a google search for the two sensors to see what they were an the engine speed sensor said * Signal application: * The signal is used for registration of engine speed and, in conjunctionwith the signal from the Hall Sender, for recognition of ignition TDCin cylinder Number 1. and the coolant temp sensor said* Signal application: * Coolant temperature sensor signals are required as a correction factorfor determination of ignition timing, injection timing and idle speedstabilization. Link to post Share on other sites
richievr 1 Posted March 31, 2006 Report Share Posted March 31, 2006 not a prob mate ... they are fairly easy to change...AND i kinda wish that was my engine, but this is mine!!!! Link to post Share on other sites
KEVIN PEAKE 0 Posted March 31, 2006 Report Share Posted March 31, 2006 Disco, what sort of symptoms are you experiencing with your motor? I also have a 1994 VR6, which at the moment is causing me a bit of grief . 99% of the time its sweet as a nut but lately [particularly when it's warm], when I stop at a junction or lights etc, it sometimes dips right down in revs and then stalls. Even if you catch it in time and give it some revs it doesn't make a difference, it's like it's just decided to die.Straight afterwards it doesn't just turn over either, you've got to give it revs straight away to stop it from dying again. These symptoms seem similar to the description of the coolant sensor given. If not this, can anyone offer any other ideas of what it could be. Cheers............................. Link to post Share on other sites
DundeeDub 0 Posted March 31, 2006 Report Share Posted March 31, 2006 Disco' date=' what sort of symptoms are you experiencing with your motor? I also have a 1994 VR6, which at the moment is causing me a bit of grief . 99% of the time its sweet as a nut but lately [particularly when it's warm'], when I stop at a junction or lights etc, it sometimes dips right down in revs and then stalls. Even if you catch it in time and give it some revs it doesn't make a difference, it's like it's just decided to die.Straight afterwards it doesn't just turn over either, you've got to give it revs straight away to stop it from dying again. These symptoms seem similar to the description of the coolant sensor given. If not this, can anyone offer any other ideas of what it could be. Cheers.............................coil pack was the problem with mine with the same problems Link to post Share on other sites
disco 0 Posted April 1, 2006 Author Report Share Posted April 1, 2006 nah mine seems to be acting a bit different than that when its warm an im sittin in traffic the idle is jumpy but it doesnt cut out. well not yet anyway!! the only other thing thats happenin is when it really rains hard it feels like its not firin on all cylinders but even that seems to sort itself out when it warms up. rite im goin get these two parts changed. just out of interest does anybody know if i'll need get the codes cleared again once the parts have been changed because ive heard that if you dont get them cleared the computer still thinks they are faulty and ignores the new parts??? was i told right or wrong??? Link to post Share on other sites
SankysVR6 1 Posted April 1, 2006 Report Share Posted April 1, 2006 Was your engine running when you had it plugged into vagcom, as if it wasn't i think that would cause speed sensor repoting a fault. Link to post Share on other sites
disco 0 Posted April 2, 2006 Author Report Share Posted April 2, 2006 not sure if it was or not i left it at the garage while they checked it. ive heard since that u have to undo the engine mounts to get at the engine speed sensor is that right or not? Link to post Share on other sites
