speed_freak 0 Posted April 3, 2006 Report Share Posted April 3, 2006 I have noticed that i have got a squealing noise coming from the drivers side of the engine however it is only on low revs upto maybe 2500 rpm after that you dont really hear it could it be the alternator belt or something else any ideas ????My car is1996 VR6 HIGHLINE WITH AIR CON Link to post Share on other sites
silverline 0 Posted April 3, 2006 Report Share Posted April 3, 2006 id say a bearing in one of the pulleys driven by the fan belt could be making the noise Link to post Share on other sites
speed_freak 0 Posted April 3, 2006 Author Report Share Posted April 3, 2006 anybody else any ideas or do you all think the same ? Link to post Share on other sites
vr200 0 Posted April 3, 2006 Report Share Posted April 3, 2006 sounds like either the water pump or the tensioner pully m8 Link to post Share on other sites
speed_freak 0 Posted April 3, 2006 Author Report Share Posted April 3, 2006 is there anyway i will be able to tell which it is ? Link to post Share on other sites
vr200 0 Posted April 4, 2006 Report Share Posted April 4, 2006 just stand over it while the car is running and rev it while stood over the bonnet m8 Link to post Share on other sites
spanky 0 Posted April 4, 2006 Report Share Posted April 4, 2006 I had the same thing last summer and it was the belt tensioner bearing that had gone. When i revved mine to see what it was loads of smoke came from the engine bay but it turned out it was just the untensioned belt slipping and on the pullies and burning the rubber off it. Link to post Share on other sites
dellert 0 Posted April 4, 2006 Report Share Posted April 4, 2006 If its the tensioner read the post "Strangled Cat", which may help. Thats probably the cause, if not remove the belt and see which pulley feels out of sorts. ie. stiff excessive endplay or making gringing noises! Link to post Share on other sites
Ciaran 4 Posted April 5, 2006 Report Share Posted April 5, 2006 i have the same thing so guess what im doing when i get home!!!can u get a new bearing for the pulley/water pump wheel??? Link to post Share on other sites
spanky 0 Posted April 5, 2006 Report Share Posted April 5, 2006 Whole new tensioner mate and new belt at the same time! Link to post Share on other sites
Ciaran 4 Posted April 5, 2006 Report Share Posted April 5, 2006 doh. just replaced the belt though when i did the power steering pump. would i be aswell doing the water pump while im their save hassle of doing it in the future???? Link to post Share on other sites
spanky 0 Posted April 5, 2006 Report Share Posted April 5, 2006 If you've just changed the belt it should be good to go back on, as long as it's not warped from running on knacked pullies. as I mentioned mine was burning rubber off it so had to get a new one, as for the water pump if you have the money it may worth getting it done at the same time if it's getting old. I didn't get it done as my water pump is fairly new! Link to post Share on other sites
Ciaran 4 Posted April 5, 2006 Report Share Posted April 5, 2006 well i wouldn't be paying anyone to do the work id be doing it myself. may just replace the belt the tensioner and the pump at the same time Link to post Share on other sites
speed_freak 0 Posted April 6, 2006 Author Report Share Posted April 6, 2006 i have now found what my noise is and the vr6 is now parked up till saturday my water pump is absolutly shot and seen as i only had the head gasket done in november i dont want that costly bill again Link to post Share on other sites
vr200 0 Posted April 6, 2006 Report Share Posted April 6, 2006 no defo not lol.. mine was mullered too, i could spin the pully while holding the pump fins still lol Link to post Share on other sites
Ciaran 4 Posted April 7, 2006 Report Share Posted April 7, 2006 how would u know if the pump was on it's way out??my car never changes in temp Link to post Share on other sites
vr200 0 Posted April 7, 2006 Report Share Posted April 7, 2006 mine never did either, i found out cause my belt came off and shredded cause the pullt went wonky Link to post Share on other sites
speed_freak 0 Posted April 8, 2006 Author Report Share Posted April 8, 2006 well when you looked at my water pump pulley it was all over the place because it was that bad but my temp never went up either just lucky that i took it to be looked at i pick it up in half hour yey Link to post Share on other sites
