feltch racing 0 Posted April 8, 2006 Report Share Posted April 8, 2006 how can i get this oil temp gauge to go down it goes upto 108 degrees when i boot it an when i sit about 60 or 70 mph it stays around 97 degrees ???im worried if i keep racing about at 130mph+ its gonna go bang Link to post Share on other sites
magentaham 0 Posted April 8, 2006 Report Share Posted April 8, 2006 Andy: it's a treet... My corrado was running 270F to 290F over here in the summer at 90mph in 110F. Tryed New Demension cooler kit, bummer...also 2 others by US after market builders, bummers... finally built my own abortion. 1990 Audi single oilfilter adapter into a XJS jag cooler. Its alot of work. I can't say if it will fit in a UK car. Haven't seen more than 238F (stomping along at 100mph in Nev.) In lu of following in my footsteps use a good sin. oil. They don't start to break down till they hit a min. of 400F. Mobil 1, Redline, Royal Purple are all good for 480F+. Some of the guys on the forum have said you can get Redline over there, Mobil ect, maybe US only.(one other nice plus to the Audi set up was getting rid of the Vr's sloppy cartridge filter for a nice spin on) Link to post Share on other sites
Justicevr6 0 Posted April 8, 2006 Report Share Posted April 8, 2006 A good quality oil can help this, I was using cheap oil and I used to get the same problem I then did an oil and filter change using good quality oil and the oil temp is running cooler. Link to post Share on other sites
badboyV6 4 Posted April 8, 2006 Report Share Posted April 8, 2006 my car is the same - fit a better oil cooler maybe? Link to post Share on other sites
VR6_Absy 0 Posted April 8, 2006 Report Share Posted April 8, 2006 Mines exactly the same it's normally i believe. It worried me when i first got mine 110 on the motorway ouch Link to post Share on other sites
matth76 1 Posted April 8, 2006 Report Share Posted April 8, 2006 Agreed...the type and make of oil affects the temp quite a lot. Semi-synthetic is ideal. What make are you using? Temps shouldn't normally go much over 100 (if at all) even pelting it down the motorway at 99mph in this country unless its a hot summer (thats not very often!). Link to post Share on other sites
Slim 0 Posted April 8, 2006 Report Share Posted April 8, 2006 Fit a Neuspeed 160 degree thermostat. They only cost £15 or so, and they make a huge difference on oil temperatures. My car is very rarely in the 90's, even after driving it hard, and I've never seen it in 3 figures once. Link to post Share on other sites
stockers 1 Posted April 8, 2006 Report Share Posted April 8, 2006 i don't consider mines 'warm' till the temp nears 100 Link to post Share on other sites
feltch racing 0 Posted April 8, 2006 Author Report Share Posted April 8, 2006 where can i get a neuspeed 160 degrees thermo ? Link to post Share on other sites
mightyvr6 0 Posted April 8, 2006 Report Share Posted April 8, 2006 I think awesomegti sells the thermostat. Ultimate cooling mods are: neuspeed thermostat, low temp fan switch, mocal 13/19 row oil cooler and water wetter in your coolant. Good oil and the correct coolant mix help too. Also give the radiator a good flush out! Link to post Share on other sites
tommy 0 Posted April 8, 2006 Report Share Posted April 8, 2006 108 is quite normal if your driving it hard...ive seen 110 on a number of occasions...mine runs at around 100 on motorways 80-90mph Link to post Share on other sites
mk3anni 0 Posted April 8, 2006 Report Share Posted April 8, 2006 I have a mocal kit on my car, and I've done away with the heat exchanger.I've never seen 100 since I fitted this, evenw hen its being thrashed it usually sits around 86-90. Link to post Share on other sites
Justicevr6 0 Posted April 9, 2006 Report Share Posted April 9, 2006 Funny how what you say can come back and bite you, I was doing a singing gig in Bath tonight and forgot my work shoes and Keyboard stand,I left the wife to set up the gear and hacked it back to Bristol and my oil temp went up to 114, I have never seen it go that high before,driving home tonight speed limit speeds it only got to 87. Link to post Share on other sites
RIX 0 Posted April 9, 2006 Report Share Posted April 9, 2006 have in the 2 previus front wheel driven vr´s,seen 118 on long trashes on german motorways. Link to post Share on other sites
kempj1 0 Posted April 10, 2006 Report Share Posted April 10, 2006 Yeah - never be too concerned about oil temps. My old GTi saw the mid-120's on the Nurburgring, and is still going strong. My VR6 has the low temp thermostat in, just becasue the old one broke. Previously the temps would go up to 110 occasionally at very high speeds, but this really isn't anything to be worried about. With the Neuspeed 160 in the temps rarely go over 100.A cooler engine generally develops more power. A hotter engine is generally more economical. VW reckon that the VR6 engine likes to run quite hot. No where near as hot as the old 8v 1.8 GTi engine though! Link to post Share on other sites
vr6matt 0 Posted April 10, 2006 Report Share Posted April 10, 2006 I think oil temps are all down to how hard you drive really, my car sits at about 92 normally, but had it upto 108 when giving it a blast. Have run my car on 0/40 and 10/40 and it still gets upto 108 just the 10/40 takes a little longer. Dont think its anything to be worried about to be honest.... Link to post Share on other sites
Buzzark 0 Posted April 10, 2006 Report Share Posted April 10, 2006 108 isn't a problem as long as you're using a decent oil and it's within it's service life (not old).Semi-synthetic e.g. the Quantam 10/40 silver is rated to 140c/150c before it starts to degrade anyway.Within it's rated temperature oil is absolutely fine, go over it and it's ability to lubricate drops dramatically and as it chemically changes the oil, permanently. Link to post Share on other sites
Leonard 0 Posted April 10, 2006 Report Share Posted April 10, 2006 VR6 motor is a hot unit anyway. Wouldnt worry about anything between 100-110 degrees. I get around 118-120 when pushing hard or 'cruising' at 120mph ;-) Think oil cooler is way to go, I will get one for increased engine life. Link to post Share on other sites
blondie 0 Posted April 10, 2006 Report Share Posted April 10, 2006 feltch u dont boot it, u drive like a grannie !dodge Link to post Share on other sites
feltch racing 0 Posted April 10, 2006 Author Report Share Posted April 10, 2006 lets have a proper race then 8) Link to post Share on other sites
blondie 0 Posted April 11, 2006 Report Share Posted April 11, 2006 u actually guna put ur foot down and not make excuses??! Cos u kno id win, hands down !amazed Link to post Share on other sites
