sortedvti 0 Posted April 8, 2006 Report Share Posted April 8, 2006 hionly got the vr6 last night. bought it off a friend. he told me it had a problem before i bought it.the car really holds back and has lost all its power. and idles funny and wants to cut out. its ok when its cold but soon as it gets warm it goes like a 1.6 (i know this cos my mate in his saxo vtr was keeping up with me)what could be the problem? hope you guys can help.cheersneil Link to post Share on other sites
matchew 0 Posted April 8, 2006 Report Share Posted April 8, 2006 inlet manifold temp sender or the blue water temp sensor or both is knackerd Link to post Share on other sites
SankysVR6 1 Posted April 8, 2006 Report Share Posted April 8, 2006 I would advise you get it on vagcom as soon as possible. Link to post Share on other sites
matth76 1 Posted April 8, 2006 Report Share Posted April 8, 2006 Could also be the cam position sensor. As said above get it on Vag Com (a decent VR6 specialist will do this for free) and Vag com will let you know if there are any sensor faults anywhere on the car. Whereabouts are you based? Link to post Share on other sites
sortedvti 0 Posted April 9, 2006 Author Report Share Posted April 9, 2006 arggggghhh are these cars loaded with sensors or what!!!! lolim based in maidstone in kentare all of these sensors expensive?a friend of mine said it could be the air flow meter, does this sound right?cheers guys Link to post Share on other sites
matth76 1 Posted April 9, 2006 Report Share Posted April 9, 2006 Could be the mass air flow sensor. If you get no sensor faults on vag com then it could be the MAF...as this doesn't always show up on VAG COM. The VR6 is no different in terms of sensors to any other car of its age. It has ten times less sensors than your modern day vectra or focus! Sensors don't tend to go wrong much in the VR... but when they do they are easy to pinpoint and fix and relatively cheaply because vag com will tell you straight away where the problem is... this is as opposed to earlier cars where you would have to spend £'s on labour to pinpoint where the problem was. A garage will run vag com on your car for free. If the problem does turn out to be your MAF you can get a reconditioned one for around £40-50. Brand new ones are just as 'delicate' as reconditioned ones so you're better off getting a reconditioned maf. Link to post Share on other sites
sortedvti 0 Posted April 9, 2006 Author Report Share Posted April 9, 2006 cheers for all the help guysmy friends dad said he would stick it on his laptop to have a look. hopefully it will be this maf thats causing all the problems. il keep you posted what it is!! where would be the place to buy one of these reconditioned maf's? Link to post Share on other sites
bazz780 0 Posted April 10, 2006 Report Share Posted April 10, 2006 buy a new one off flea bay mate, Link to post Share on other sites
sortedvti 0 Posted April 10, 2006 Author Report Share Posted April 10, 2006 well i took it round to my mates and his dad said that the car was too old for the plugs he has got for laptop.he plugged in a fault code reader and it didnt do anything. was guessing this is because the car is chipped and the reader didnt like it. so the next step is to buy another maf!are all the maf's the same for each model or does the vr6 need a specific one?seen a couple on there and it doesnt list it for the vr6also where would i find the 16pin plug that the pc plugs into? Link to post Share on other sites
bazz780 0 Posted April 11, 2006 Report Share Posted April 11, 2006 mate, easiest option will be to get the car diagnosed properly before spending any money, could well be another sensor. get it on a diagnostic machine, read the codes, if no clues then clear all and then take it for a spin and stick it on again to get the newest code/fault reading. Link to post Share on other sites
sortedvti 0 Posted April 11, 2006 Author Report Share Posted April 11, 2006 well i see a maf on ebay for £10 so i didnt wanna miss out, so i bought it. only a tenner so not too bad. yeah if this dont work then il definitely get it on the laptop.also when i turn the igniton on it say's "in 02" on the left hand digital display. is this a normal thing or is it telling me something? Link to post Share on other sites
thegoth 5 Posted April 12, 2006 Report Share Posted April 12, 2006 The in02 is the telling you it wants a (major) service.TG Link to post Share on other sites
johnemerson38 1 Posted April 12, 2006 Report Share Posted April 12, 2006 what does a major service include Link to post Share on other sites
spanky 0 Posted April 12, 2006 Report Share Posted April 12, 2006 Haynes manuels have a full list of all the things that need doing for all 3 service alerts. Link to post Share on other sites
sortedvti 0 Posted April 19, 2006 Author Report Share Posted April 19, 2006 right. had it put on the computer and it was showing a fault. so looked under the bonnet and the guy spotted a plug had come loose from the dizzy. plug it on and problem all sorted.cheers for all the help guys. neil Link to post Share on other sites
petervr6 0 Posted April 19, 2006 Report Share Posted April 19, 2006 did you get the car cheap because of theis problem? if so you got a result then just being a plug that had come off !amazed Link to post Share on other sites
sortedvti 0 Posted April 19, 2006 Author Report Share Posted April 19, 2006 yeah got the car cos it didnt run right and it didnt have and mot. also had a knocking noise when you pulled away.well the knocking noise was a bolt loose on the lower arm which is now fixed and the mot all in all cost me around the £200 mark give or take a couple of quid.so me thinks i had a bit of a result. yeah couldnt believe it when the guy just plugged it back on and said all fixed. hahahaha.all i need to do now is fix a minor dent on the rear quarter and the car will be mint condition. Link to post Share on other sites
