Crozo 0 Posted April 26, 2006 Report Share Posted April 26, 2006 Hello all my VR seams to be missing but only when I try to keep to a constant speed like 30mph when I accelerate is seams fine and only misses every so often but to add more confusion it dose not all ways do it some times it is fine.I have changed the plugs and ht's so dose any one have any ideas as it is starting to drive me mad %-6 Any help would be grate Link to post Share on other sites
Ciaran 4 Posted April 26, 2006 Report Share Posted April 26, 2006 coilpack or leads start the car at night pop the bonnet and check for arching u will soon notice Link to post Share on other sites
6potmkII 0 Posted April 27, 2006 Report Share Posted April 27, 2006 best thing is diagnostics test so you dont go wasting your money on things you dont need, but, imo if youve changed the plugs and leads, my next move would be afm. also could be coilpack or hall sensor.i just got rid of my misfire at low revs, it was the afm Link to post Share on other sites
Crozo 0 Posted April 27, 2006 Author Report Share Posted April 27, 2006 Thanks for the advice but without sounding thick what is afm and am best off going to my local VW garage for a diagnostics Link to post Share on other sites
Petesvw 0 Posted April 27, 2006 Report Share Posted April 27, 2006 Most independant garages now have diagnostics, wouldn't go straight to VW unless you have £££ to burn! No one in your area on here with VAG.com? Link to post Share on other sites
Peakz 0 Posted April 28, 2006 Report Share Posted April 28, 2006 Crozo, I've been having a similar intermittant fault . . . So far I've replaced Coilpack (had a crack in it), ignition leads and platinum plugs to no avail.I then replaced the ECU relay (#109) and the fuel pump relay (#679 I think) which came to £31 and so far it hasn't played up all week.Another part to this is that sometimes the car willnot start, it cranks perfectly well for ages but takes a few attempts before it starts but as I mentioned above, I've not had a problem since replacing the relays. Link to post Share on other sites
Eat this 2 Posted April 28, 2006 Report Share Posted April 28, 2006 clean the throttle body with carb cleaner then reset the throttle body Link to post Share on other sites
Crozo 0 Posted May 1, 2006 Author Report Share Posted May 1, 2006 [blockquote]Another part to this is that sometimes the car willnot start, it cranks perfectly well for ages but takes a few attempts before it starts[/blockquote] I have had that as well thanks for the info & thanks to all the other ideas everyone Link to post Share on other sites
mightyvr6 0 Posted May 1, 2006 Report Share Posted May 1, 2006 Crank sensor on its way out? You really need to get it on vag-com/vw diagmostics if you can't find the problem, having searched for other possible causes. Link to post Share on other sites
Crozo 0 Posted June 19, 2006 Author Report Share Posted June 19, 2006 hello all i have now had the car put on to a diagmostic computer and there are no folt coads to sugest a problem with missfiring ? :-( and the misfiring is now happening more and more often. if any one has any ideas it would be grate, Link to post Share on other sites
ian 182 0 Posted June 19, 2006 Report Share Posted June 19, 2006 If you know someone with an independant garage they may help.My mate has the latest "snap-on" diagnostic stuff and when he done mine it took it through something like 100+causes and fixes before it came up clean.Might be cheaper than VW doing itian Link to post Share on other sites
gav_113 0 Posted June 19, 2006 Report Share Posted June 19, 2006 i had a similar prob once, my leads were arching out, so i got some new ones and a new cap. fitted the whole lot, and drove down the road and it was missing all the time. i noticed that the cap was arching out on the head? turned out that the electrode thinging which contacts the rotor arm had completely broken up. so maybe check inside cap m8. Link to post Share on other sites
clarkie 1 Posted June 20, 2006 Report Share Posted June 20, 2006 spend a bit of time checking all the wires on the main wireing loom plug as i had a wire broke there on mine . that mad it misfire and was even worse in reverse. also check all the wires that go to the mass air flow sensor and all the other wires. its worth it before you go forking out loads of cash. Link to post Share on other sites
dstyrrell 0 Posted June 21, 2006 Report Share Posted June 21, 2006 are you certain its a misfire?, i had a dirty throttle body and it had the same symptoms aparently vr's are prone to this. mate took mine off and gave it a major clean and problemo solved, i was fearing the worst also as mine was stalling at junctions and not starting and spluttering sounds like you've got the same prob mate. Link to post Share on other sites
jonnyedinburgh 0 Posted June 23, 2006 Report Share Posted June 23, 2006 ;)how do i clean the TB, is this fairly easy to do? Also, how do i test the MAF and can it be reapired if it is faulty or is it a replacement job? Link to post Share on other sites
Crozo 0 Posted June 26, 2006 Author Report Share Posted June 26, 2006 hello all on sunday i spent the day fault finding and after spending most of the day under the bonnet the problem has revelled its self, plugs 1 & 6 were a bit burnt so i swopped them and problem solved.so some times it can be the simple things Thanks all for your help and suggestions, Link to post Share on other sites
