Whitedog 0 Posted May 5, 2006 Report Share Posted May 5, 2006 Hi AllJust a quick one. What is this at the rear of my cat (round circular thing with a big hole in it?). +o( Do i need a new cat??? :-( Link to post Share on other sites
kilokilla 0 Posted May 5, 2006 Report Share Posted May 5, 2006 Hi mate if its engine side of cat its for lambda probe if its at back of cat ie tailgate end of cat its probably a cat off of a later car that has lambda before and after cat you should be able to just stick a bolt in this hole but make sure you get 1 with the right thread on it and do it up tight otherwise it will just blow it back out which im guessing is what has happened. Link to post Share on other sites
Whitedog 0 Posted May 6, 2006 Author Report Share Posted May 6, 2006 Its definately at the rear of the cat, ie tailgate end. Will it be a threaded hole then? i take it it is so it can take a sensor. just worried that there should be something there. Cant understand what you mean by it probably being of a later car as mine is a later car, 1997, therefore, shouldnt it have something there???Cheers for your help folks, hope i make sense. Link to post Share on other sites
kilokilla 0 Posted May 6, 2006 Report Share Posted May 6, 2006 What i mean is it could be off of a later vw not a vr as a lot of later vws have similar cats but with lambdas before and after cat. Link to post Share on other sites
spanky 0 Posted May 8, 2006 Report Share Posted May 8, 2006 I had exactly the same thing in winter, when I could see the exhaust gases coming out the from under the side of my R reg '97 VR. Did just as KiloKilla mentions and not had a problem since! Link to post Share on other sites
Whitedog 0 Posted May 9, 2006 Author Report Share Posted May 9, 2006 Cheers folks, will do it the weekend when i can get it up on axle stands or something. Any idea what size thread on the bolt??? I'll probably buy a selection and then try it. Cheers again. Link to post Share on other sites
spanky 0 Posted May 9, 2006 Report Share Posted May 9, 2006 tbh I used exhaust paste around a snug fitting (as in snug to push into the hole) bolt so I didn't have to destroy any threads etc, then wiped the excess paste off the bolt head and it looks clean and tidy. This may sound obvious but don't use a really long bolt as you may knack your cat! Hope this helps Link to post Share on other sites
